I found an old tap
/ I found an old tap #1
Quebecguy
Sutton, Quebec
IH 354, John Deere 5205
Whoever forgot to remove this cast iron tap out of this sugar maple probably isn't around anymore. I've chiselled out some wood to show the spout better. I was lucky in that my chain was pretty well worn out anyway so it is in the scrap pile now. The tree was uprooted by the wind last autumn - I would never cut a healthy, mature maple as I plan to keep sugaring for a while yet.
/ I found an old tap #2
Looks like you pretty well center the saw on the tap. I did the same thing with my chain saw - LARGE engulfed chunk of angle iron in big Ponderosa pine. As luck would have it - I found it with my chain saw. Best we could figure - something to do with a gate originally being hung off the pine when it was much younger.
/ I found an old tap #3
I found some metal in a 5' Madrone I was cutting up. I never saw it but the chain went dull suddenly and when I went to sharpen it there were some broken teeth. I had to take a lot off but it's still useable.
My place was a farm from the 1880s to 1930s. There's old fence and pipe everywhere. I think this tree got used to hold up fencing when it was small.
/ I found an old tap #4
Found a pair of pliers in a crotch of a tree with a chain saw. Tree had completely engulfed them and was in an area that was on the outskirts of town when the home was first built.
/ I found an old tap #5
Finding tap lot better finding horse shoe...ouch.
/ I found an old tap #6
The worse I've found was a rock that somehow the tree grew around. It was about 2 feet up. No sparks, just all of a sudden started cutting slow. After a few moments I stopped but the damage was done.
/ I found an old tap #7
Barbed wire, buried in tree. Resharpened chain, hit more right after! Dang I was Poed!
Lots of sawyers leave out the first ten feet of any tree because of metal that will ruin their mill blades.
/ I found an old tap #8
Famous tree up our way, at least you would know metal is in there. At least for a few more years anyway.
/ I found an old tap #9
Is that the Lance Armstrong tree?
/ I found an old tap #12
Cut up a Lot of Barbed wire. Worst was a log chain that was used to hold the tree fork together on a big old Elm. Ruined the saw chain but the log chain was still in pretty good shape.
/ I found an old tap #15
Around here if the tree is willow ,lombardy poplar , or cotton wood you check for evidence of old fences as these trees were often planted as posts. Then cut at chest high to avoid the wire.
The most interesting item I saw in a tree was an old cross-cut saw left in a fork of a pinus radiata.
1500 Gallon Stainless Steel Tank (A64127)
1500 Gallon...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
Coleman Back Home Screen House (A62613)
Coleman Back Home...
2021 Sol Grand Design BK390 Camper (A62613)
2021 Sol Grand...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
