I found a off the shelf touch up paint that matches
   / I found a off the shelf touch up paint that matches #1
Trikejay
Tennessee
LS XG3135
I found an off the shelf touch up paint that matches
It is Rust-Oleum professional safety blue. It matches perfect. The only difference is there's a slight sheen difference. The sample I'm holding up is painted with Factory LS touch up paint on the left side and the Rust-Oleum on the right side. The Rust-Oleum is just slightly glossier. I can't tell the difference in color in the shade or in the direct sunlight. It is a much better match then the sail blue that I also tried.
   / I found a off the shelf touch up paint that matches #2
Re: I found an off the shelf touch up paint that matches
Thanks for the update. I have to buy a couple rattle cans of paint today and I'll look for the "professional blue" and check it out. Appreciate the information.
   / I found a off the shelf touch up paint that matches #3
And you *know* after a week or two in the southern sun, that sheen will be gone! :)
   / I found a off the shelf touch up paint that matches #4
Try doing the last pass a lot farther away if you're in an area where overspray isn't a mess. That will dull the finish a bit too
1608 (A57192)
1608 (A57192)
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
