I finally started my pond
   / I finally started my pond
Brandi, the size of fuse is more often controlled by the gage of the wire leaving the fuse box, going to the receptacle. 15 amps is the normal size for a 14 gage wire. 20 amp is normal for a 12 gage wire. Protection for individual loads is normally done by a circuit breaker installed in the load circuits. So, your pump would work fine with the 14 ga/15 amp feed wire and it should have an internal breaker or motor overload protection built in.
How do you plan on controlling the pump? Are you plannng to use the breaker as a switch or put in a dedicated switch and/or receptacle? I recommend a motor control switch rather than a normal light switch. A circuit breaker is not a good choice for a switch because they are not designed to be switched off/on on a regular basis. A light switch may fail often due to the inductive load of the pump's motor. The best circuit would be to put in a motor control switch and a GFCI receptacle at the location of your hookup.
EDIT: If your pump has a built-in switch, all you need is a GFCI receptacle, of course.:)
Thanks Jim. I have decided to move it out of the barn as it makes too much noise mounted on the barn wall. I will move it out to the pond dam bulkhead. I will make a fake rock out of chicken wire and mortar mix and bury the power wire to the house. I will research a motor on/off switch.
The wire I am going to use is 10 gauge wire that was used as temp wire to power my air compressor until I could put in the permanent 2 gauge wire. I buried 2 gauge for welders out in the barn. So the wire is way overkill for the vacuum pump/air compressor, which is why I wanted a lower rated breaker.
Oh yeah...I need to go get more white rocks from Welding Is Fun's place. A fake rock costs around $80. So I plan on making a fake rock for the pump from this link... How to Make Fake Rocks | eHow.com
hugs,. Brandi
   / I finally started my pond #442
hugs,. Brandi
Brandi, those rocks are still sitting where you saw them last. Anytime you are up this way drop on in and pick a few tons.:rolleyes:
   / I finally started my pond #443
Well, nobody can ever fault you for putting in a breaker smaller than the maximum for the wire size. In a dedicated circuit, you can rate that breaker to protect your load. My aerobic septic system has a dedicated breaker box with two breakers and is fed from the main breaker box. One is for the aerator pump and the other is for clear water reservoir pump to my sprinkler heads. Except for overload protection in the motors, neither of these circuits has any other protection. Since the system is serviced only three times per year, those breakers also serve as switches. Three times per year is not an excessive amount of switching on a CB.
I'm going to search back to see if I can find a link to your pump. If you have a link, I'd like to have it. I'm also considering a aerator pump for my deep pond within a year or so. . . probably more so.:eek:
EDIT: I found your earlier link to the eBay site where he provided a link to Thomas. I've found technical information, but no wiring recommendations, so they may not exist on the manufacturer's site.
   / I finally started my pond #444
The stumps that I can see in my pond that are exposed have caves dug under them. What I have noticed that the fish really like is the tangle or piled up trees. Seems like the bigger the mess, the more activity it gets. That's why I'm putting entire trees into my pond. This is something that I've just realized and decided on, so the timing is really bad now that I'm getting some small showers. It's steep getting out of my pond and the tractor is spinning it's tires.
With yours, I would put a dozen logs across the bottom. Some resting on the undereater island, and some going up to the shoreline and even poking up above where the water line will be when full. The best structure for the fish isn't the prettiest to look at, but it's what they want and use. I've come to think that seeing logs stick out of the water is a good thing. I especially like getting a picture of a bird or turtle on top of it.
As for fishing, I had some kids out here over the weekend, and they lost several of my hooks on my logs. It's just part of fishing, and I have plenty of hooks, so it's not that big of a deal.
Eddie
Lee,
Thanks. Looks like the 1st or 2nd weekend of November. Tell Kay I for me.
hugs, Brandi
Jim,
I bought a used oil less vacuum pump/ air compressor off of ebay for $68 plus shipping. I am trying to "cheap Charlie" it. But I might go ahead and buy this pump Pondmaster AP100 Linear Compressors @
Aeration Systems full line if the ebay vacuum pump doesn't work out long term.
This website is the best I have found of aerators and prices.
I also bought a rebuild kit for the vacuum pump for $20. It has not arrived yet.
hugs, Brandi
Eddie
Eddie,
As always, you have good ideas I never thought of. I like the idea of logs on and off the underwater island and a lot coming up out of the water. I will look into it the last weekend of the month. Thanks again.
FYI......I have been wanting to put some boards out to the island and check the deep at the deep end. The logs will help. Do you think pine logs about 10 inches in diameter will do? I have some pines that size I have been thinking about taking out. Or would you suggest oaks?
hugs, Brandi
   / I finally started my pond #448
Eddie,
hugs, Brandi
I worry that pine will rot out real fast. I know that pines under water have been known to last centuries, but they have to be a certain depth. I don't know about the ones close to the surface, and those that come out of the water.
Here in my area, pines where left standing when they built Lake *********, and decades later, the stumps are still sticking up out of the water, so maybe they will be fine?
Eddie
   / I finally started my pond #449
Brandi, we pick up christmas trees for a donation for the swim team. We take lots, tie them together and sink them (use scrap web to make rock bags) in our favorite ice fishing spots and fishing has picked up immensely (for rainbows, dollie varden, and greyling) since we started doing it. A few pine or cedar trees sunk into your pond would make great habitat and you could grapple them out if you wanted to.
Rick,
I am going to try the logs stacked up on the island. I can always toss some small ones in between the logs.
When will you be leaving your fish camp for the winter???
hugs, Brandi
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2011 Ford F-150 Crew Cab Pickup Truck (A55788)
2011 Ford F-150...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2019 Dodge Grand Caravan SXT Van (A55853)
2019 Dodge Grand...
