BukitCase
Elite Member
- Joined
- Feb 17, 2012
- Messages
- 2,756
- Location
- Albany OR
- Tractor
- Case 580B, Long 460, Allis-Chalmers 160
Thanks, it kind of evolved - I first got the mag drill because of making implements/addons to 2 tractors and the backhoe; large holes and hand drills are for MUCH younger people than me.
Then I wanted to be able to use it in more cases, so I built the gray-sided 10x12 "vise table" that's bolted in place of the fixed jaw on that darker blue vise - mag drills want pretty thick steel for best holding power, so that gray table started as a 12" piece of 10" channel, beefed up with 1/2" plate and flat bar across the end - the top surface is 1/2"x3" FB, welded up - welds ground then surfaced on the mill.
There's enough room on both sides of the vise to clamp small pieces of angle, etc, as stops for repeatable hole spacing. Instead of needing a flat area around the hole that's at least 3" x 6" for the magnets to grab, this setup can drill an inch and a half hole thru a piece of steel that's 2" square if I need to.
The xy table was next when I needed to make adjustable legs on a 24' square modular roof system for a 20' container so I could work on the tractors in winter - the adjusters in those pics (3 of them) each have 24 1/2" holes (12 per side, perfectly aligned side to side) plus another 11/16" hole for the welded nut, so 25 holes per leg - all three legs took just under one hour to drill ALL the holes, including setup time.
Here's a few more pics of those parts... Steve
