Tires I could use some tire advice R3039H owners
   / I could use some tire advice R3039H owners #21
Not loaded. Most of the time I stay in 2 wheel drive unless I'm plowing deep snow.
   / I could use some tire advice R3039H owners #22
Do all of you have your rear tires loaded?
I do and with a loader would not do it any other way, also to lift my coal bags i have a counter weight for the 3 point hitch
The R3039H I'm looking at has a backhoe on it. The dealer said with the backhoe as ballast, I shouldn't have a problem. But I see the backhoe getting in the way while doing loader work.
   / I could use some tire advice R3039H owners #25
Ordered mine on Monday. Had dealer to load tires before he delivers it. Wouldn't have one with a FEL without as much weight on the back as possible.
   / I could use some tire advice R3039H owners #26
As I have come full circle back to farm environment but this time a country estate, I have been surprised at the discussions on whether to ballast tires or not. Been away from tractor talk for 30 years or more. It was always a no brainer around my neighborhood as a as a youngster. Basically it was a way to make any tractor match up to the next up size tractor without ballast. Farmers always wanted to get the most tractor for the money. Water was cheap back then:)
   / I could use some tire advice R3039H owners #27
R4 are a good all around tire , I actually perfer R4 if you need to run your tractor on pavement, if you plan to use them for snow removal i would invest in a set of chains , R1 will have much better traction but a rough ride and higher tread over paved roads or driveways ..loading the tires in my opinion is a must these compact tractors have a lot of horsepower to weight.
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
Hose Reel (A55787)
Hose Reel (A55787)
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
