I believe the Hype.
   / I believe the Hype. #1
davygp38
where NY,NJ, and PA all meet
Kubota L4400
I was at my local welding supply store a few weeks ago, and he gave me some 80t AC plus rods to try. he said they were high strength, easy to use, and made nice welds. I was using 7018 rods in my latest project, and I was doing fine. Unfortunately I left the whole can of 7018 rods out, with the cap off. I didn't want to take a chance with the 7018 rods, being a little damp, so I tried the 80t rods. All I can say is wow! They were quiet, low splatter, easy to strike, and they made my welds look like I actually knew how to weld. I was burning them with the Everlast power arc 200 (dc). If you are an amateur welder like me, I would give them a try. I went back to the store, and bought 10 pounds, to finish up the project. Don't get me wrong, I would not use these rods as an all in one rod, I would still use a 6010, for the root pass on something heavy duty like a tractor implement, but I think I would make the rest of the passes with this rod. Any feedback would be appreciated.
   / I believe the Hype. #3
Sounds impressive.
I tried looking it up, but can't find out much on the internet.
Who makes it?
   / I believe the Hype. #4
messerwelding
80T-AC+
• This alloy was designed as a superior fit-up, assembly and tack rod
for all low carbon steels.
• Features touch strike and re-strike characteristics.
• Ultra low spatter and easy slag removal.
• Use with AC or DC (either polarity).
• Value packed in an attractive multi-colored corrugated carton.
Index
   / I believe the Hype. #5
Great JJ.
Thanks :thumbsup:
   / I believe the Hype. #6
How are they priced to 7018, and can they be used for the root pass?
   / I believe the Hype. #7
MG 80T AC. I used to sell it. It was marketed as an 80,000 tensile 6013 rod. It really has no AWS Classification because it was once a propriatory formula..All I can say is I still use it. You have to try it. Runs like 6013, Holds like 8018..
   / I believe the Hype. #8
so would that make it something like an 8013 then :)
soundguy
   / I believe the Hype. #9
Yes sir. If you could boil t down.. I once worked for a filler metal company that send 10 sticks to Ohio State for evaluation. ( they do that ) The end result was yes, It is 80+,000 tensile. that is all they would say. I hate to pitch an MG rod but you can strike an arc and lay the stinger down..It will weld until the rod is gone..Done it, Like to show it..
   / I believe the Hype. #10
reminds me of a brand I found once at the local gas dealer.. was called 'ez' or easystrike or similar. I swear you could strike an arc on a wet napkin with one.. mu guess is they were closer to the performance of a 6013 though looking at the weld / penetration / surface.. just easy to strike and hold an arc.. even on those lil 120v buzzboxes..
soundguy
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
JOHN DEERE 9520 LOT IDENTIFIER 266 (A53084)
JOHN DEERE 9520...
2011 CATERPILLAR 140M2 MOTORGRADER (A51246)
2011 CATERPILLAR...
PALLET OF ARMSTRONG CEILING TILES (A51248)
PALLET OF...
16ft Heavy Duty Aluminum Ramps (A53472)
16ft Heavy Duty...
