I Beam help needed
/ I Beam help needed #81
Do a Google for Beamboy 2.2 and you will be happy.
Joe
</font><font color="blue" class="small">( Part of my lake design will have a cement spillway to handle the runoff during heavy rains. This could involve a million gallons of water, so it needs to be a substantial spillway that will not erode.
It will be built at the edge of my dam on virgin soil with a shallow drainage to the creek.
To handle large quantities of water, I need to make it 18 inches deep and 16 feet wide. I'm gonna add a few feet to this and build it 20 feet wide.
The sides will also be concrete, which will create an area that will be very dificult to get through when walking along the dam. It will also be impossible to drive over unless I build a bridge across it.
I want to put two I-beams across the span. My thinking is that I'll rest the ends of the beam on a concrete footing. In the center I'll fasten the I-beam to a concrete footing with some large bolts.
This should allow for expansion of the I-beams with the changes of tempatures. They will be spaced at the width of my tractor tires and decked with PT 2x6's.
My question is what sized I-beams can I use to span ten feet and support a 4,000 pound tractor? Lets say 6,000 pounds max weight for both beams combined?
Or if anybody knows the link to a page with the ratings for various sized I-beams. I can buy any size, but would prefer to not waste money buying something rediculous.
I've also read through all the previous posts on bridges without seeing anything that would work. I'm not going to do the trailer method or any other scrap material. Only new I-beams will be used.
Thanks,
Eddie
)</font>
/ I Beam help needed #82
Eddie,
A single 20' span is a steel solution for your application IMO. Technically you may just make 40lbs/SF loading with the 2 x 12's, depending on the exact lumber grade, but that's not enough. Those 2 x 12's @ 12" OC and broken into 10' spans would be slight overkill IMO. 2 x 10's @ 12" OC on a 10' span should get you well past 50lb/SF live load. I think that 50lb/SF live would be the minimum design criteria for people only. That's generally a design minimum for residential PT wood decks, allowing for people standing in close proximity to one another (nearly packed), which you may experience on that bridge. Derek or one of the other Engineers may know the actual loading minimums for your application. The 2 x 12's @ 12" OC over 10' may be about right for a golf cart?? Not certain what those weigh though. Maybe 600 lbs. + occupants and a cooler of cold of course /forums/images/graemlins/grin.gif
/ I Beam help needed #83
Building codes vary by region but are usually very similar. Live load for corridors, stairs, and egress is usually 100 psf. It can be reduced to 40 psf for single family dwellings but this is public. I do not know off hand the load requirement for foot bridges but I would use 100 psf or determine the AASHTO requirements. I would believe that they would still govern since it is a bridge.
To use tables developed for 50 psf decrease the spacing required to be half that in the tables to support 100 psf.
…Derek
/ I Beam help needed #84
I would build a 4' wide bridge with the 2x12s on 16" centers. This would require 4 of them and you could use the beam tables for 12" centers because you have 4 beams in the 4' width. Continuous beams will be stronger than two 10 foot spans.
You have been working with wood for long enough to know how to deal with slight warpage and bends.
Go for it...and send us pix.
Since we're just talking here and throughing ideas around, how much difference is there from 12 inch centers to 16 inch?
I'm thinking of using 5/4 for the decking and blocking the 2x12's, but havent decided on spacing. The ends and middle for sure, but wonder if ther's any advantage to more than two points in the span?
Also, does the size of the blocking affect overall integrity? Such as 2x12's versus 2x10's, 8's or 6's?
Thanks again for all the advice and suggestion.
Eddie
/ I Beam help needed #86
"Continuous beams will be stronger than two 10 foot spans."
Dave,
I'm not understanding that. Do you mean that a 20' joist, that is center supported at half span, would be stronger than (2) 10' joists end to end? I wouldn't agree that there would be any difference given adequate bearing, but I just wanted to make sure you didn't convey that a 2 x 12's spanning 20' with end bearing only, are stronger than 2 x 12's spanning 10' each. I know that wasn't/isn't your intention. Just making sure a real novice didn't read it literally and make that interpretation, as I nearly did.
Or perhaps I have your comment out of context?? Wouldn't be the first time I've done that /forums/images/graemlins/wink.gif
Also, note Derek's comments on 100 PSF. I thought commercial might have different loading thresholds. Something to consider.
/ I Beam help needed #87
That is exactly what I am saying. To be very precise, a 20' beam supported at both ends and at the center will be stronger than two 10' beams spanning the same supports.
This was covered in about the third week of introductory mechanical engineering. The fact that the beam is continuous imposes constraints on the deformations of the beam near the center support which increases load-bearing capacity.
You can Google "continuous beams" and find more information on this (and a lot of companies selling software to do the calculations).
Span tables do not take this into account, and I am not suggesting that Eddie should take credit for it, just that it will provide an extra safety factor.
Back when I learned about this (dinosaurs still frolicked in Central Park), the calculations were so complex that only the largest projects took credit for the addition. Most designs used the equations for discontinuous beams and then recognized some additional safety factor.
Today, even the smallest overpass takes the effect into account because we have computers to do the calculations.
Saying that was certainly never my intention. It is clearly not true.
My intent was to convey that 20' beams do have an advantage over 2 - 10' beams which is probably worth the extra few dollars.
It just seemed to me that a longer beam, one the goes the full distance, would have more sterngth by being longer and spread out over a larger distance. I think it's something like how the decking will increase the strength of the beams by distributing the weight over a larger area. Or at lest that's how I figure it in my mind without any actual knowlegde here.
I do the same for decks. I always use the longest beams I can get to spand the deck. If I have to use two in a run, I make sure their joint never align with the next one over and have as large an overlap as I can.
Thanks,
Eddie
/ I Beam help needed #89
"(dinosaurs still frolicked in Central Park)" Me makes two.
All my time around this and I wasn't aware the a single beam in a center supported situation was stronger (to a degree) and that it warrants consideration. Soon as I thought about that it made sense though. I can see the limits on deformation at the center (what would be center bearing points on end to end beams). Seems it wouldn't change or mitigate much on the deformation occurring at the ends of the 20' beam though.
If we are talking wood beams (joists) that capacity gain (from limited deformation) would be differernt than with steel. Any thoughts on that? With wood I don't know that I've ever seen it considered. As you stated, that's generally just a span, + species, + live load determination to get to a size and spacing. Now I could see it as a consideration in engineered lumber and perhaps trusses where true application calculations are more likely.
/ I Beam help needed #90
I'm no engineer and make no claims, but I am a residential frame carpenter. We use wood Ijoists for our floor systems. The floor layouts are engineered. I am pretty sure they take into account if there is a center support with a continous joist over it. Someone explained it to me like this. (I don't know if it is right, but it made sense to me!) When one side deflects, the other span helps to resist this force. If they are spliced over the center, each span acts independently.
Jason
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2004 Volvo VNM S/A Day Cab Truck Tractor (A59230)
2004 Volvo VNM S/A...
2019 Bobcat T870 (A60462)
2019 Bobcat T870...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2023 Kearney (A60462)
2019 KUBOTA SIDEKICK RTV-XG850 (A62130)
2019 KUBOTA...
