I added a Prince RD522 to my MF 1528 and it is barely working.In fact It was to control a frail mower but it can now barely lift the FEL. Whats wrong
   / I added a Prince RD522 to my MF 1528 and it is barely working.In fact It was to control a frail mower but it can now barely lift the FEL. Whats wrong #11
What do I do with the other line that is connected to the Tee of the power beyond?
Does your RD522 valve have the power beyond feature installed and operable? If yes then power beyond from factory valve connects to pressure on the Rd522. Power beyond of RD522 connects to the line that was on the factory valve. So the oil flows from factory valve through RD522 then to what ever function the factory power beyond was feeding. Only line that you can tee into are tank lines.
The RD522 should have three lines connected to it to operate as power beyond valve
Pressure, power beyond and tank that must connect directly to tank.
You need to get rid of the tee on the existing power beyond fitting. You need a power beyond sleeve in the new valve (and yes, It's way too big for your application) and a third line from that valve for a sump return. Sump return is the ONLY place a tee can be used in this type of circuit. As oldnslo stated, all valves MUST be plumbed in series.
Ok, so when I remove the tee at the power beyond where does the other line go or is it just capped off.
   / I added a Prince RD522 to my MF 1528 and it is barely working.In fact It was to control a frail mower but it can now barely lift the FEL. Whats wrong #13
See if this might help you out.
  • Prince Hyd valve RD5000 pluming.pdf
You need to get rid of the tee on the existing power beyond fitting. You!
Got it, I will try tomorrow.Thank you so much!
   / I added a Prince RD522 to my MF 1528 and it is barely working.In fact It was to control a frail mower but it can now barely lift the FEL. Whats wrong #15
You need to revisit the entire plumbing package. Your second photo shows what appears to be a power beyond sleeve, so the line from that fitting probably leads to the three point lift system. Yes/no? If so, remove that tee (save it for later) and connect the pressure line to your new valve (the one you now have connected to a tee on the pressure side of the original valve) to that now vacant fitting. You will need a power beyond sleeve to fit your new valve (as shown in the attachment from Leejohn) and a hose from that goes to the line leading to three point. The line from the fitting you're now using as a return line from the new valve will connect to tractor sump. This is where your tee comes in. I'm guessing (because I can't see where it goes) the other fitting in your second photo is the sump return. If so, that fitting is where the tee needs to go and the existing return hose from the new valve will go there. I'm no good at adding and drawing diagrams so all I can do is explain things in English.
Here's the theory. Oil flow from the pump goes the inlet of the existing valve, flows through that and out the existing power beyond sleeve. From there it goes to the inlet of the new valve, flows through that and out the (not yet acquired and installed) power beyond sleeve and into the three point lift system. The sump return from both valves can be connected together anywhere and sent back into the tractor sump.
You may need to read through that a few times to get a handle on it, and you may need some different fittings and/or hoses to make it all work out.
I just wanted you'all to know that after making the changes you suggested all is working. You were right about the valve being to big. It is very jumpy, so I have ordered an 11 GPM with a 3rd port so I can add a hydraulic top link. Saturday is not the day to look for hydraulic parts. I went to several local stores-Tractor Supply and Advance Auto not in stock-Oreillys auto parts did have the parts I needed to make the changes just for your information. Again I can't thank you enough for the great advice!!!
Also putting the control on the left side was a poor decision. When new valve comes in I will arrange it on the right side.
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
1999 Toro Reelmaster 5400-D 100in Fairway Reel Mower (A59228)
1999 Toro...
2020 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
