I’m thinking it’s finally time for a change
   / I’m thinking it’s finally time for a change #41
Far as I'm concerned, unless you can get 0 percent financing through the manufacturer or some sweetheart deal, now is a very poor time to buy any large investment anything, houses included and vehicles because interest rates are climbing, inflation is out of control and nothing will change until after the election on November 5th, depending on who gets the Whitehouse and I'll leave it at that.
Do they have a MT342? That size machine is closer to your New Holland tractor size. Not sure if money is an issue or you just dont want to go that big, but something to think about.
The MT342 is 3-cylinder. My present TC40D New Holland is a 4-cylinder, hence the reason I chose the MT242HC = 4-cylinder
Presently LS is offering 0% interest, pretty hard to beat
   / I’m thinking it’s finally time for a change #44
Today I had a chance to drive a 3-cylinder as well as a 4-cylinder LS MT series tractor. I was pleasantly surprised with both although the 4-cylinder was smoother and it seemed quieter. Also thought the fit and finish was as good if not much better than my original New Holland Boomer. Tomorrow I’ll set the sale in motion for a LS MT242HC which is the 42hp version, with 4-rear remotes & 3rd function plumbed to the FEL. Might as well get all the bells and whistles. Before you guys recommended LS I had no idea they even existed so thanks for the tip!
I wasn’t pleased with the LS brand 3rd function. You may want to try one before ordering.
   / I’m thinking it’s finally time for a change #45
I put a W.R. Long 3rd function on my MT342. Works very well. That’s what my dealer does on their machines.
D&D, what was wrong with the LS 3rd function?
To the OP. Congratulations on the MT242. That is there new model, and I believe that uses a Yanmar engine.
   / I’m thinking it’s finally time for a change #46
Please double check those 4 rear remotes. My thinking is that it will have 4 couplers-(2 rear remotes. I know of no tractor under 85HP that even offers 4 sets (8 couplers) of rear remotes.
If the dealer is adding 3rd party stuff, that is one thing, but check about that many factory sets.
I doubt it though, hope that I'm wrong, that would be super cool to have 4 sets of OEM rear remotes. (y)
Last thing, are you sure that an 1800lb lift for the 3pt is going to be enough?
   / I’m thinking it’s finally time for a change #47
So is Kubota and has been but I work (play) at a Kubota dealer part time and you can bank on the fact that any manufacturer that is offering 0 percent financing is rolling that finance charge into the pricing.
   / I’m thinking it’s finally time for a change #48
I believe you are correct on that 2 sets of remotes or 4 couplers. When I bought my first M9000 in 72 I special ordered it with a dual speed PTO, creep gears and 3 sets of remotes with flow control but I had to order it that way. The used one I bought a couple years ago has 2 sets only (4 outlets) and I could stack on some more but I have no need.
I believe you are correct in your assumption. Under 85 horse, only 2 sets. really no need for more in a utility tractor anyway unless you want flow control for the top set. I rarely use all 3 sets myself.
   / I’m thinking it’s finally time for a change #49
Not so much wrong, I didn’t like it. You roll the handle to the right to get the 3rd function use, then the 3rd function button has to be held down while using. Just feels clunky/awkward. Hooked up my auger which was actually uncomfortable as heck trying to hold the handle right while holding the button.
Personally, it’d be nice if the tractor and parts suppliers quit calling them 3rd function valves/kits/ Not really what they’re offering.
   / I’m thinking it’s finally time for a change #50
My experience with NH was parts were expensive with long lead times to get them in at the dealership.
TYM isn't on my radar because there isn't a dealer network or presence here. I would never consider an expensive machine without any support.
I've had good luck with parts pricing and availability on my Kubota's which is why I keep buying them. Knocking on wood even obscure parts from 30 year old attachments and 15 year old machines have been in stock or available within a business day or two and are reasonably priced. I have 3 local to me dealers (within 50km radius) to call on as well.
If this is a hobby then you are rolling the dice. If you are doing this commercially buy two TYM machines, maybe you will have one available to run when you need it...or at least have spare parts on hand.
The general rule of thumb is you get what you pay for.
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
Deere 310L (A53317)
Deere 310L (A53317)
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
