Hydrualic Leak L3710
   / Hydrualic Leak L3710 #1
Captain Dan
Vermont
Kubota L3710GST/John Deere 318
I'm a new owner of a L3710GST and noticed that there was a hydraulic in the clutch housing drain plug. It is one drop a minute so it leaves a nice puddle on my garage floor. I am thinking this must be from the primary transmission shaft seal. Has anyone had any problems with this? Is this a know issue? My tractor is a late SN acording to the dealer he thought it was 2004 but was not sure. It has had very light use and I'm surprised that a seal would go so early.
Has any other Kubota owner had this problem?
   / Hydrualic Leak L3710 #3
I also own a 3710GST. I have not seen this problem. I am not sure I understand were the leak is coming from. There is a drain under the clutch housing to drain off water. Is that were it is coming from?
Yes, so I assume it is either the transmission shaft or a gasket inside the clutch housing. I am going to the dealer today to discuss and to find out how much it will cost to repair. I may be about to learn more about this tractor than I wanted to. But I do really like this one.
I just spoke with the dealer and he said this was not unusual and that it is probably the shaft seal. He said sometimes the bearing goes and that causes a real mess. The cost will be $1300 plus parts.
   / Hydrualic Leak L3710 #6
I previously owned a 3710 GST, but didn't have that problem. I think it is just one of those bad luck issues. The 3710 is a very reliable tractor IMHO.
Thanks for the encouragement. I like the tractor and it is perfect for my needs. Debating if I want to split the tractor myself or let the dealer do it.
Caterpillar 303.5 (A50120)
Caterpillar 303.5...
2018 Bobcat T595 (A50120)
2018 Bobcat T595...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
2022 CATERPILLAR 272D3 WHEELED SKID STEER (A51242)
2022 CATERPILLAR...
