Hydrostatic vs Non
/ Hydrostatic vs Non #81
... I think cars became automatics with the advent of more and more woman drivers when in 1970, laws were passed to allow woman to drive. Convenience is king as is less stocking chaffing.
So women in RI weren't allowed to drive before 1970? :eek: Good thing it a small state where everything is within walking distance. :laughing: Although as your legs get shorter it becomes a longer walk.
/ Hydrostatic vs Non #82
I have both gear and hydro and each has its place. I think the best transmission any tractor can have regardless of size is a power shift. I had that on my old Yanmar and I could work circles around a similar sized New Holland with HST transmission when we were digging out a dried up pond and transporting the spoils about 100 feet. The NH had to downshift to L range (only has H and L with rabbit and turtle in each) to dig, then stop to put in H to travel while I just power shifted to 1st to load and back to 4th to travel. I never had to touch the clutch as it is all hydraulically controlled.
I don't know why there is not Powershift transmissions in CUT tractors as they are really the best of both worlds. NEXT to a Powershift, an HST seems to be best for everything but tillage work and bush hog work on large pastures. For those activities, I prefer gear drive. For cutting the lawn grass it has to be HST in a Zero turn mower.
Both gear and HST have strong points for use, but for the average CUT owner who can only afford one tractor with todays choice of only gear or HST, I suppose HST is the winner.
Some of that could simply be the tranny in that NH. I'm not a big fan of two ranges with creeper and rabbit setups. Most of the time I run my LS is the middle range, and it has enough power to dig into the pile, and is still fast enough for moving 100ft or so. Some of the newer HST setups would be even better with auto downshifting, etc.
/ Hydrostatic vs Non #83
No , they were driving anyway because since they got the vote, they had gotten rather uppity and thought they should be able to do anything. They passed the law so they wouldn't have to prosecute anybody and husbands be able to actually live with their wives. Before then, a married couple had to build two houses. I think the lawmakers are doing the same thing now but with other laws.
/ Hydrostatic vs Non #84
Well, I've watched enough "I Love Lucy" and "Dick Van Dyke" reruns to know that before 1970 married couples slept in two separate beds, but I didn't know they needed two houses?
/ Hydrostatic vs Non #85
Cheez, don't you just get sick of the propaganda that was fed to us back then. That was only so they wouldn't have to relocate for camera shots. and then, the concept caught on that couples may not have needed two houses. It helped ruin the economy.
/ Hydrostatic vs Non #86
Well I have always like a gear tractor, and now I have a standard shuttle shift. I really like it a guess mainly because that is how I was raised, it could also be because I am cheep! Now it seems like I need surgery on my back I was using the tractor the other day and my left foot is well sort of numb so driving the standard shuttle really wasn't as fun as usual.
/ Hydrostatic vs Non #87
Might ought to mention that the Yanmar Lx490 has a power reverser that literally will allow you to not use clutch at all if you wanted to not. You can start with everything in neutral, select the range you want, put it in the gear you want and then move the shuttle/power reverser to forward or reverse. Never touch the clutch. Change directions at will without a clutch. It does a smooth stop and then a smooth reverse. Smoother than I can do it manually. Usually for speed of changing gears you would use the clutch when you move shift grears but if you wanted to you could just move shuttle to neutral, change gear and then return shuttle lever to the direction you want. No clutch useage. It is why I bought the Yanmar. Really had settled on a must have for next tractor to be hydrostat but there were some situations with hydrostat I just did not like for my purposes. The power reverser got me a good bucket tractor while still having gears. We will see if it all pans out. Just unloaded the tractor today. No seat time except to make sure that what I just said is true. Hope this helps some poor shopping soul and doesn't drive you even more into consternation:)
Might add that I am sure I will be using the clutch for fast gear changes but just wanted you to know that you do not need your feet except for brakes if you wanted to drive it that way, such as when you have had injury to a foot of leg or it just is giving out after a hard day. Also the clutch is so easy to push it is easiest to use that I have seen> I don't know if that due to something inherent to having a wet clutch or if it is just the implementation. Anyway it is extremely soft to push and a short stroke. So far I just love this thing.
/ Hydrostatic vs Non #88
With a gear drive when you shuttle forward to reverse, don't you have to come to a stop and step on the clutch?
With the L3800DT yes I do and it's not a problem.
With the L3750 hydro shuttle, no need to stop or use the clutch.
I like the L3800DT better. :D
/ Hydrostatic vs Non #89
Well I have been around tractors all my life. I like a hyro in small tractors with a FEL. If you moving dirt the shuttle may be nice, but if you in a really low gear as soon as you have the bucket full and you pull the shuttle lever to reverse (power or syncro) you still in that low gear. With a hydro you can fill the bucket and then reverse at a faster rate. I know I do. I cant stand it on a gear tractor to get the buck full then hit reverse and be creeping back. Now if I'm in a field pulling a disc or something heavy....of course a gear tractor. On other thing is I had a dealer tell me the other day that in 25 years selling tractors he has never been into a hydro tractor. He said you keep the maintenance up like anything else.
/ Hydrostatic vs Non #90
So do I. slickest thing since sliced bead. New operators wont be tearing up the transmission, wife neighbors, they are truly durable. I have a hydro that has worked hard since 1973 and have driven big and small. It is getting a little slushy now but still strong at full throttle.
My tractor is 49HP doing a 7 foot bushog, and quite a bit of pulling around in the fields up and down hills. Hydros just do not hold speeds real well in a lot of those situations, you have to be paying attention to speed in order to maintain it, Cruise controls just wont take care of up the hill and over down the hill and back up etc. And boy do they whine.
Around the yard, and dirt pile and gravel pit and just plain digging all day, hydro is way to go hands down in my book. But this power reverser tractor will get in there and dig with them pretty well. Even in higher gears at just above idle, it will dig into pile until wheels are slipping, and a coordinated, foot throttle outburst and the bucket is coming up fast, power reverser has made a smooth shift with out me having be coordinated my self, and I am coming backwards as fast as I would want to be moving. This tractor will spin the wheel at just above idle in the 5 mph gear, that much I know, and the gear can be changed on the fly if I want to go even faster once I get to moving forward with the load. Once I realized all that I was willing to make the compromise so that I would not be let down out in the fields, covering the miles with hay rakes, balers, wagons, bushog, and occasional session with a breaking plow. Hydros seem to bet much more tolerant of the jerking and snatching when you are into just about to destroy the loader type of hammering into stuff, like construction equipment has to do when working with rocky or clay with undersized machine. The hydro hangs in there where a clutch gear combo will not.
I know it is hard to settle on what you really need since you need both. I spent a year looking around, avoiding John Deere because of price, but found the Yanmar, the John Deere with Yellow pain,t and it fit what I was looking for. It was a pretty good stretch to give up on the hydro for this particular tractor purchase, and the Yanmar made the stretch for me.
I am not trying to convince anyone. Just want folks to know that a shuttle shift has a lot of different implementations. The Branson has just a forward reverse dry clutch mechanism, like so many of the other shuttle shifts. It would work you pretty hard in a constant back and forth situation, or jockeying into something. This power reverser is a whole nother capabability, f a it is built with durability included in the design and not thrown together to just to meet a price point for that function. Wet clutches, and planetary gears are usually used when drives with durability are in mind. I expect it will hold up to responsible use. I don't expect to having to go inside. I am not going to use it hard enough to tear it up. But we will just have see.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2014 Bobcat T550 Compact Track Loader Skid Steer (A59228)
2014 Bobcat T550...
207270 (A52708)
207270 (A52708)
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
