Hydrostatic vs Non
/ Hydrostatic vs Non #21
Well, I'll just come out and say it - it's my dad that is so anti HST and it's one of those things I'll never stop hearing about. Might not seem like much, but some of you may understand.
As a kid I bush hogged 60 acres of his fields every other year with an old ford geared tractor. I can remember some situations where the ground was rough and I had to lower the rpms to stop from abusing the tractor, but then you would lose PTO RPMs as well.
I have a gravel driveway, so I need to be able to go pretty slow sometimes, yet have enough power to move the snow.
Thoughts?
Those old geared Fords like the 8N were just geared too high for most jobs. These newer geared tractors have plenty of different ground speeds to work with. I rarely use 1st and 2nd, because they are too low for most stuff.
yea; I think it was an old 8n. It had a 6 volt system. You could go out in the dead of winter and crank that thing for 20 minutes and it would just keep turning over until it started. I think it only had a 4 speed transmission. I remember my dad got it as junk, installed the rear PTO himself and we ran it for 20 years. It was about 5000 lbs I think, but even in first gear there were times where you couldn't go slow enough without getting nearly bucked out of the seat.
To think I was 15 or so years old running that thing around with a huge bush hog on the back - no seat belt or ROPS. Things were a lot different then.
/ Hydrostatic vs Non #23
Thoughts?
If you are going too fast, just ease up off the pedal. The engine stays the same speed and the tactor moves slower (because you have an infinately variable gear ratio within the HST).
I think your dad needs to investigate it further.
/ Hydrostatic vs Non #24
Aside from the higher initial cost, many people would argue the other points are wrong. Many mechanics have said that they fix/repair/replace more parts on gear transmissions than HST....clutches get fried, gears get abused, etc. There just isn't that much evidence that HST systems have higher maintenance costs associated with them. Some HST systems whine more than others, but in many, it's most noticeable when the RPM is too low for what you're trying to do..that's the only time I really hear mine.
I gave an honest pro and cons to the OP. YOU would argue.
I've never bought any hydraulic filters specifically for my gear transmission. That's an on-going maintenance cost.
There are plenty of threads about HST problems in all brands, they do fail, the sensors surrounding them fail, they are more complex. You don't get the ease of HST use for nothing.
Compared to a gear transmission, all HST's whine, that would be the salient point in a comparison.
If I have to burn extra fuel to make an HST happy and/or not whine, that is hardly a plus.
Fried clutches are pure operator error or people don't adjust them periodically. A five minute job that requires no parts.
We owe the OP valid comparisons such that he can make the right decision for himself. I don't care which he chooses. His Dad's opposition to HST has made him question a popular choice, he is trying to evaluate the situation.
/ Hydrostatic vs Non #25
Mine's HST. Love it when I have something chained up that I need to "rock it" to get it moving. Also works well planing off a little at a time with the loader
/ Hydrostatic vs Non #26
The 8N had no High/Low range and 1st gear just wasn't low enough. Newer tractors have High/Low which makes them much mo better. :)
/ Hydrostatic vs Non #27
I didn't argue at all, I just said that many people with a lot more experience than I have say otherwise. Seriously, a $15 filter every year or two is a factor worth even thinking about? I don't know about all brands, but my HST doesn't require extra fuel to be burned, it just requires that you don't lug the engine...don't do that (which is bad anyway) and the HST doesn't whine at a level almost anybody would complain about. Heck, gear transmissions make noise too, so it's not exactly all or nothing.
You are right about helping the OP, and that's what I was trying to do. I have both gear and HST, and like both, so I'm not against either kind. Some references for what I was referring to...a bunch of folks with a ton of experience (certainly more than me):
http://www.tractorbynet.com/forums/...ssion-vs-hst-transmissions-3.html#post3419997
Been working on tractors for 34 years and I sold tractors for 7 years in New England and in this area of the country Hydro rules. We very reluctantly took gear tractors in trade as they would become lawn ornaments, had to pretty much give them away. The hydro's are pretty bullet proof, never had to repair one.
http://www.tractorbynet.com/forums/...ssion-vs-hst-transmissions-9.html#post3425457
Kind of back to the original question - the gear transmission is easier to work on. Have had brother-in-law's gear drive Kubota apart multiple times to replace broken parts - no gears yet, just shift linkage pieces breaking - and 2 guys can have it pretty well completely lying on the floor in a couple hours. Finding where the broken pieces end up is the biggest time killer. Have not yet had to tear into our hydros. Unless you feather the lurch (wear), the loading is abrupt whereas the hydro takes time for the swash plate to move so the load on the power train is automatically feathered.
http://www.tractorbynet.com/forums/...ssion-vs-hst-transmissions-9.html#post3425684
I've been following TBN threads since 2001 and there just isn't any significant number of HST transmission failures. There was an L48 that had a bad control valve recently but the actual hydro pump/motor package was apparently OK. I figure keeping the hyd fluid full, fresh and clean is job #1, probably next is avoiding overheating from using it in an abusive manner.
There are a lot of hydrostatic systems in equipment these days... powersteering, drivetrains on combines, payloaders, the list goes on and on. Hydro was newfangled technology in the 1960's but today it's totally mainstream and very reliable. As a drivetrain, it's one choice available, has its good and bad points. Reliability is actually more a strong point in its favor.
http://www.tractorbynet.com/forums/...sion-vs-hst-transmissions-11.html#post3448882
My tractor score is now 11 HSTs and 5 gear-drive units, 4 purchased new. I wrenched on all of them, including clutch replacements and HST rebuilds. For my use here in the mtns, I prefer HSTs by far, but I do not plow fields.
To the OP's question, I am very confident that HSTs are very reliable, and potentially more reliable
than foot-operated dry clutch gear tractors.
/ Hydrostatic vs Non #28
I have owned 5 tractors, 2 gear 3 HST.. I am never going back to a gear. Hydro is safer on Hills, not the other way around. Hydro's whine a little.. Little hydro tractors whine a lot. Big hydro tractors whine very little. There is an extra filter to buy every 400 hours. Big deal.. There is NO clutch on mine to replace or wear out or adjust.. Hydrostats have a better repair track record than gear/clutch tractors. Hydrostats are much easier to operate for all operators, but especially for new or inexperienced operators. Hydrostats allow for infinite ground speed. Hydrostats eat some power. They will not put as much to the ground or the PTO as a Gear machine. In loader operation hydrostats are much less fatiguing on the operator, and allow you to concentrate on the loader not the transmission. If you want the maximum horsepower delivered to the ground buy the gear. If you want convenience, reliability, and safety of operation buy the hydro. Oh and to answer your question, expect to pay about $1000 more for the hydro, but you will get it back when/if you trade it in. (this has been a paid political announcement, worth exactly what you paid for it:))
James K0UA
/ Hydrostatic vs Non #29
I agree with everything the previous 2 posters say. There simply is nothing wrong with the reliabilty of the hydro transmission. Skid loaders are a good example of an application that absolutely tortures the transmission, and they hold up well. John Deere's biggest CUT, the 4720 has 66 engine HP, and a hydro tranny is the only way it comes. The lower HP ones come either gear or hydro.
The hydro is easy to operate, and safer for most applications. It is great for backing up, your not reaching for brakes, clutch,shifter....just turn around and feather the pedals.
I would go so far as to say that for a utility tractor, you would be crazy if you didn't like a hydro better.
Now plowing the back 40...I would rather have gears, no sense in throwing away 5-10% in fuel with no benefit whatsoever.
/ Hydrostatic vs Non #30
The hst will do fine for what you need. Unless you are going to be working on steep hills. Then you should get a shuttle shift.
Why is HST not good for steep hills? I actually purchased HST specifically because I have steep hills. Increased weight, increased speed control, it always remains "in gear" and never "free-wheels".
HST has multiple ranges as well. When needing precise control to move around slowly, HST is the way to go. You can't go as slow on a geardrive system without slipping the clutch, and it will never be as smooth as HST at small precise movements.
/ Hydrostatic vs Non #31
I noted popularity and resale in my first post, #8. So you want to tell me something I've already said?
This is not informative except either: bad BIL who cannot operate a clutch properly, or is power shifting the tractor, or bad parts.
Anything abused will break, gear or HST. The poster notes good points and bad points.
This poster has fixed both gear and HST but likes the potential of HST and the safety in the mountains/hilly terrain.
I don't see any evidence there that HST units are less to maintain or less prone to break. It wouldn't be a real big worry to me, and the OP may not even get a choice depending on his other selection criteria.
I have seen two posts recently in the NH area about probable clutch issues. The posters did not read their manual, and did not seem to be aware that clutch adjustment is routine maintenance. I don't know how well they would fair on any kind of tractor. It's difficult to separate the mechanical aspects from the art of using a clutch well.
A recent poster in the NH area asked what the purpose of the three filters (beyond the main hydraulic filter) on his hydro unit could be that he needs to either clean or replace.
I just hope Hiker88 can have the tractor he wants while keeping his Dad reasonably happy and avoiding any "I told you so" recriminations. Who knows, maybe his Dad will grow to appreciate an HST?
/ Hydrostatic vs Non #32
I'm not even remotely an expert on the topic, and I'm not sure if it's specific to any make/model tractor, but at steep angles, it's possible to starve the pump of fluid in HST systems. As I recall, that can cause damage, can get you stuck, or lead to a dangerous situation where you're suddenly freewheeling. There was a better discussion of it in the thread linked on the first page here.
/ Hydrostatic vs Non #33
Me too!
Anything is possible. My neighbor is an old-school guy who really only likes antique tractors, and wants everything gear so he can work on it himself. I think he could work on an HST unit just fine (he just built an airplane from nothing but plans!), but he's skeptical. We've done a bunch of things together, and now he's starting to say "bring the hydrostat, it'll be better" when he asks me to help him....not always, but sometimes!
/ Hydrostatic vs Non #34
I usually recommend renting something as close as possible to what you are going to buy for a day or two to get a real feel for it, often tooling around on the lot doesn't give you the full effect. A tractor also tends to "shrink" once you have it on your property a bit, one of my favorite tractors was one I initially discounted as too big with more power than needed.
I was initially underwhelmed with my Kubota L5740 from driving it on the lot, been running it over a year and couldn't have picked a better tractor my needs.
I grew up driving geared tractors 10+ hours a day and still have and use one, but when practical though, I will get in the HST.
/ Hydrostatic vs Non #35
...I know someone who is really down on hydrostatic transmissions and just wondering if there is any truth at all to it...
You know what they say about first impressions. Anyone who was around farm equipment in the 1960's got a first impression of hydrostatic drives from a new model introduced by International Harvester that was the first farm tractor with HST. It was an otherwise beautiful unit of 100+ hp, but the HST was not up to the demand of heavy tillage farming and gave many owners trouble. Most farmers I have known have very long memories, and are not easily persuaded to change an opinion. 99% of the time, those are very admirable traits, of course.
The experience many people have had with hydrostatic drives on lawn tractors hasn't helped either.
But many of those folks don't know that the hydrostat has matured a lot and is now widely used in large farm equipment such as combines and in heavy industrial equipment such as Caterpillar track loaders. And it's great technology for small (under 75 hp) tractors.
Of course there's nothing wrong with straight drive setups either. I have both kinds and don't mind working with either. The HST would be my preference because it's more convenient... at my point in life that means a lot.
/ Hydrostatic vs Non #36
This is the same thing as Solid Lifters against Hydraulic lifters back in the day as Hydraulics were prone to collapse.
/ Hydrostatic vs Non #37
I love my shuttle shift, gear driven tractor. I always have the power where I want it. Now for a mower, that's different, I would do hst.
/ Hydrostatic vs Non #38
I never thought about it, but you are right. Hydraulic lifters are another example of power-wasting oil squishers. :laughing: When is the last time you replaced a leaky or lazy solid lifter?
Seriously and joking aside, out of curiosity, I read this article:
Dyno Shootout: Solid Roller Vs. Hydraulic Roller | StangTV
Not sure about the validity/fairness of the cam choices used in the test, but solid lifters won by a hair.
I did see many performance after-market hyd. lifter sets advertised so I will assume they have become the norm.
/ Hydrostatic vs Non #39
In my 41 years growing up on a farm and still working on a rather large row crop operation, I have never seen hydrostatic transmission equipped equipment fail, not saying it won't , because any thing can. Reliable, I think so, are they for everyone with a small tractor, probly not. I love mine on my 4200 Deere. For loader work and mowing it is great. I even disk food plots with it. Really shines doing box blade work also, maintence costs are arguable, to me, it isn't a issue. It wouldn't matter what brand I would have bought, it would have had a HST. My next tractor will be the largest available with it also. LUTT
/ Hydrostatic vs Non #40
The problem with the whole hydro vs gear argument is hydro vs what gear type. Power Shuttle has all the advantages of gear and tge advantages of HST, but is nearly as much money as HST, and seems to be limited to ~35+hp tractors. When people say hydro only.for loader, they often are thinking that the only gear tractors are the plain "clutch and hunt for gear" types.
Peanut Wagon (A64127)
2018 Bobcat MT55 (A64126)
2018 Bobcat MT55...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
2020 FREIGHTLINER 114 SD CEMENTECH VOLUMETRIC MIXER (A65643)
2020 FREIGHTLINER...
2021 Bobcat T770 (A64126)
2021 Bobcat T770...
