Hydrostatic vs Non
/ Hydrostatic vs Non #102
If you are trying to decide between a hydrostatic and gear transmission for your tractor, think of the letter "L", when it comes to when the hydro is better: 1) Lawnmowing 2) Loader work 3) Landscaping 4) Ladies 5) Lazy folks.
If you or your usage don't fall into those 5 categories then you might be best served with a gear transmission.
/ Hydrostatic vs Non #103
Add no Left leg fatigue. :)
/ Hydrostatic vs Non #104
Got to love the whining noise and extra heat from a HST. I own two and jumping on one of my antique gear tractors is pure pleasure. Just got a new Kubota yesterday, you would think with today's technology HST would be more quiet.
/ Hydrostatic vs Non #105
My tractor is used mainly as a loader , off road fork lift . I couldn't imagine driving a manual in and out of all the tight spaces on my property and control a load. we have a manual nursery fork lift at our shop and I avoid it like the plague. {clutch is iffy , brakes work some times] that don't help.:drink:
/ Hydrostatic vs Non #106
so you are saying your Hydro toy gets you more ladies than your STick? Makes sense. Gotta run. It's beer time on the ponderosa.
/ Hydrostatic vs Non #107
Mine is.
/ Hydrostatic vs Non #108
Mine quieted down considerably when I upgraded to the Super UDT hydro fluid at my 400 hour maintenance... at about 25 bucks/gallon. I bought the tractor used with 180 hours so have no idea what was in it before.
/ Hydrostatic vs Non #109
:thumbsup::drink::salute:
/ Hydrostatic vs Non #110
This is a LX2610 and it ships with Super UDT2. Manual says filter changes at 50 - 200 - 400 hours but oil doesn't get changed until 400. Same tractor as B2650 and it looks like others indicate HST noise.
/ Hydrostatic vs Non #111
Noticed your tractor is a larger compact. I also have a Kubota L4330 that the HST is quiet. It's more of a small tractor HST issue. I had a 27 HP LS J2030H (NH Boomer 25), just traded in, that also made more HST noise than the larger tractor. Maybe the larger mass dampens the noise better.
/ Hydrostatic vs Non #112
Yes, that is been my experience as well. The larger the tractor, the quieter the hydro. I think it may have something to do with the size of the passages that the oil flows thru. But I can't prove that. I run SUDT2 in my tractor as well.
/ Hydrostatic vs Non #113
If you are trying to decide between a hydrostatic and gear transmission for your tractor, think of the letter "L", when it comes to when the hydro is better: 1) Lawn mowing 2) Loader work 3) Landscaping 4) Ladies 5) Lazy folks.
Now that's funny :D :cool2:(...and true!) I fit in 4 out of 5 and the one I don't fit in, my wife really wanted to be able to use the tractor every now and then... (so glad she spoke up, I was aiming to get a gear transmission).
/ Hydrostatic vs Non #114
It is for sure. I had never used a hydro, until about 15 years ago, when my brother in law gave me his old Ingersol Lawn-mower tractor. After using that, I could never go back to a gear tractor for that regular usage. I do keep a gear lawnmower around, for when the grass gets too thick and I can't afford to loose the efficiency, but 95 % of the time I cut my acre of grass with a hydro. I blew the engine in the Ingersol after a couple years and have had (2) more hydros since then. The John Deere LT150 that I use now and was given to me by another brother in law, is still going strong.
As far as the loader work goes, I don't do a whole lot of it, and I get by ok with a "power-reverser" JD 4120 at home. That is basically a gear transmission that you don't need to clutch. The Case 580C hydro TLB, that I used at work, was much nicer for that. Landscaping is about half loader work and half lawn mowing, so the hydro is definitely better there. Some day, I might try and get our 16 year old girls to help with the lawn mowing, but I would never attempt it with a gear-drive. There is certainly more physical effort involved in using that.
/ Hydrostatic vs Non #115
So is mine. M59 Kubota.
/ Hydrostatic vs Non #116
I see this is an older debate. I知 not brand loyal or transmission loyal. Doubt I get the hours on any compared to many on here. But I. I壇 work in logging industry for a while. The equipment takes as much or more abuse than a farm tractor and most of that equipment was hst. I壇 haul 5 cords of wood over stumps on mountainsides and the hst was never an issue .
Ford 7000 (A64127)
Ford 7000 (A64127)
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
Volvo EC55B Exvacator (A62679)
Volvo EC55B...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
