hydrostatic trans fluid change
   / hydrostatic trans fluid change #1
lexus114
Bethlehem Twsp. PA
06 LT-1045 LE (v-twin)
Is it very hard to change the trans fluid in my LT-1045?
   / hydrostatic trans fluid change #2
Yes, sort of. It's a sealed unit that's not meant to have the fluid changed. But you can do so by removing the tranny from the tractor and turning it upside down. I believe it drains out a breather vent or something. You refill through the same hole.
   / hydrostatic trans fluid change #4
If you just want to do it as a preventative maintenance measure, I'd just do sucessive suck-outs and refills of the exansion tank. Without a tank, as said, you pretty much have to remove and invert the unit. Unless you want to flip the whole tractor over or drill/tap a drain hole! Here's your trans: Hydro-Gear ? LT Series
Joel
The old lubed for life deal huh? Well,thanks for all of the input guy`s.
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
3 plastic drums (A53117)
3 plastic drums...
black Max power washer (A53421)
black Max power...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
