Hydrostatic question
/ Hydrostatic question #1
Hinomotoman
Western NC
LS R3039, Hinomoto E2604, Hinomoto N239, Case IH 1140, White Field Boss 31
I have a Mitsubishi built Case IH 1140. When I bring the tractor up to operating temperature and pull the trans dipstick there is a release of either pressure or vacuum. I can't tell which. Is this normal for a hydro or should I drill a vent hole in the fill cap?
Eugene
/ Hydrostatic question #2
Eugene
could leave it alone and have less condensation inside the transmission .
/ Hydrostatic question #3
If there is a pressure/vacuum issue, you'll start blowing out seals & leaking fluid. There should be a breather somewhere & I bet it's plugged. Look under the seat they often hide under there.
/ Hydrostatic question #4
My first thought too. If you have a loader, I can't see how it would not have blown out when you lower the loader rapidly, but I have never seen a tractor transmission, hydro or gear that wasn't vented.
/ Hydrostatic question #6
Take a carefull look at the filler bung. It may have a built in vent.
That is what the Kioti's have. Most of the Kubota's seem to be under the seat. I can't speak to other brands.
Thanks guys. I'll check for a vent this weekend. No loader. There is an axle housing seal leaking pretty bad.
Eugene
/ Hydrostatic question #8
X4 on the vent. My JD855 has a curved tube under the seat right by the fill cap. It was clogged tight. Fortunately mine had a 1/8" pipe thread and could be removed for cleaning. If I removed my dipstick with it hot it would blow fluid out at me and I could hear it hissing through a seal when I parked it. Cleaning the vent tube out fixed it.
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2015 Bandit 200UC Chipper (A63689)
2015 Bandit 200UC...
2022 EZ-GO ELITE...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2022 EZ-GO ELITE...
