Hydrostatic question
/ Hydrostatic question #1
Hinomotoman
Gold Member
Western NC
LS R3039, Hinomoto E2604, Hinomoto N239, Case IH 1140, White Field Boss 31
I have a Mitsubishi built Case IH 1140. When I bring the tractor up to operating temperature and pull the trans dipstick there is a release of either pressure or vacuum. I can't tell which. Is this normal for a hydro or should I drill a vent hole in the fill cap?
Eugene
/ Hydrostatic question #2
Eugene
could leave it alone and have less condensation inside the transmission .
/ Hydrostatic question #3
If there is a pressure/vacuum issue, you'll start blowing out seals & leaking fluid. There should be a breather somewhere & I bet it's plugged. Look under the seat they often hide under there.
/ Hydrostatic question #4
My first thought too. If you have a loader, I can't see how it would not have blown out when you lower the loader rapidly, but I have never seen a tractor transmission, hydro or gear that wasn't vented.
/ Hydrostatic question #6
Take a carefull look at the filler bung. It may have a built in vent.
That is what the Kioti's have. Most of the Kubota's seem to be under the seat. I can't speak to other brands.
Thanks guys. I'll check for a vent this weekend. No loader. There is an axle housing seal leaking pretty bad.
Eugene
/ Hydrostatic question #8
X4 on the vent. My JD855 has a curved tube under the seat right by the fill cap. It was clogged tight. Fortunately mine had a 1/8" pipe thread and could be removed for cleaning. If I removed my dipstick with it hot it would blow fluid out at me and I could hear it hissing through a seal when I parked it. Cleaning the vent tube out fixed it.
Ford F-450 (A63689)
Ford F-450 (A63689)
Morbark M12D Wood Chipper (A63689)
Morbark M12D Wood...
Landhonor Plasma Cutter (A66408)
Landhonor Plasma...
2005 DRAGON END DUMP TRAILER (A65643)
2005 DRAGON END...
2013 Caterpillar 420F 4x4 Extendahoe Loader Backhoe (A64194)
2013 Caterpillar...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
