Hydrostat pedals
/ Hydrostat pedals #21
MossRoad said:
Now I'm confused... do some HST units have a clutch for something? :confused:
Yup, mine does. I need it for starting, changing ranges, engaging either PTO and if ever need be - towing.
How do these other HST's work without a clutch? How do you know for sure that nothing is engaged. If that JD breaks down on a paved drive/road and you need to pull it aside to safety or onto a trailer, how do you put it in nuetral. That electronic switch is not going to work if the tractor is not running. Here comes the "My JD never breaks down" posts. :rolleyes:
/ Hydrostat pedals #22
My JD has a "N" in the selector range. I would assume you would select neutral and it would roll.
/ Hydrostat pedals #23
Is this selector range the electronic part you mentioned. If it is electronically controlled, it's not going to work when the tractor is off or has a dead battery.
/ Hydrostat pedals #24
I'm not Tact but I can answer. The neutral is a mechanical neutral just like range A,B and C. Stop, select range with lever and go. No clutch needed. Neutral is true neutral.
PALLET OF SITE FENCE STABILIZERS (A62131)
PALLET OF SITE...
UNUSED WOLVERINE SB72-72" ROCK BKT (A62131)
UNUSED WOLVERINE...
2001 JOHN DEERE 770CH MOTORGRADER (A62129)
2001 JOHN DEERE...
48ft. 38 Ton T/A Flatbed Trailer (A61568)
48ft. 38 Ton T/A...
UNUSED REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED REMOTE...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
