Hydrostat pedals
/ Hydrostat pedals #21
MossRoad said:
Now I'm confused... do some HST units have a clutch for something? :confused:
Yup, mine does. I need it for starting, changing ranges, engaging either PTO and if ever need be - towing.
How do these other HST's work without a clutch? How do you know for sure that nothing is engaged. If that JD breaks down on a paved drive/road and you need to pull it aside to safety or onto a trailer, how do you put it in nuetral. That electronic switch is not going to work if the tractor is not running. Here comes the "My JD never breaks down" posts. :rolleyes:
/ Hydrostat pedals #22
My JD has a "N" in the selector range. I would assume you would select neutral and it would roll.
/ Hydrostat pedals #23
Is this selector range the electronic part you mentioned. If it is electronically controlled, it's not going to work when the tractor is off or has a dead battery.
/ Hydrostat pedals #24
I'm not Tact but I can answer. The neutral is a mechanical neutral just like range A,B and C. Stop, select range with lever and go. No clutch needed. Neutral is true neutral.
New/Unused AGT MX-CRT23 Mini Skid Steer (A61166)
New/Unused AGT...
MANCHESTER 80 GALLON AIR COMPRESSOR (A62131)
MANCHESTER 80...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
2017 Grand Design RV Toy Hauler Camper VIN # 573FS4334H1108024 (A61166)
2017 Grand Design...
2023 Nissan Altima Sedan (A61569)
2023 Nissan Altima...
