Hydrolics
/ Hydrolics #1
cn8cg
Reddick, FL
Jinma 254
Can air in the intake line burn up the pump? I know it should be spelled "HYDRAULICS" but......
/ Hydrolics #2
If there is not enough fluid in the supply line, then you certainly can burn up the pump.
The pump needs fluid for lubrication, plus it has the job of pumping.
/ Hydrolics
It has PLENTY of hydraulic oil. My pump died and was wondering it air entry was the cause. I now have it replaced and examining the drive shaft, it was broken. So air was not the cause in the first place. Thanks JJ. I appreciate you input. Jules in Central Florida
/ Hydrolics #5
Welcome to TractorByNet. Good luck with your repair.
/ Hydrolics #6
:welcome: to TBN
/ Hydrolics #7
A broken shaft may be an indication of a deadhead situation, where the pump stopped turning because there was no place for the fluid to go, with the engine still running.
It could have burst the pump or valve due to incorrect hookup.
/ Hydrolics #8
cavitation could snap the shaft, because it could give big hyd spicks. If pump is cavitating and get a shot of oil it could give you a spick more the system relief valve can handle. Doing it a number of times and the shaft could snap. Kind of like poping your clutch over and over at high rpm sooner or later something snaps.
2022 John Deere 5055E (A62177)
2022 John Deere...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
2015 Bobcat T770 Compact Track Loader (A64047)
2015 Bobcat T770...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
