Hydrolic top link Pros? Cons?
/ Hydrolic top link Pros? Cons? #1
RandyinMS
Ashland, MS
Farmall Cub
Hey Everyone,
I have a LS4150 with dual remotes. I'm thinking about using one for a hydraulic top link. We are using the LS primarily for field cultivation, road maintenance and bush hogging. None of my growing collection of implements uses hydraulics and I don't see any in my near future.
So, I'm asking what are the pros and cons of a hydraulic top link.
Pro's-on the fly adjust-ability others?
Cons??????
/ Hydrolic top link Pros? Cons? #2
What implements are you using or planning on buying for the road maintenance? I ask because a hydraulic top link is a real help for some of these tools.
/ Hydrolic top link Pros? Cons? #3
I honestly can't think of a con, we use them on all our tractors with rear remotes and it helps no matter what we have on the 3PH and helps hooking up equipment.
/ Hydrolic top link Pros? Cons? #4
For rear blade and box blade use the hydraulic top link is great, but I'd recommend getting an additional hydraulic side link to really make those implements get more done in less time. It's amazing how much time it saves, just by letting you make little adjustments and see immediate results. An unexpected benefit is using top & tilt cylinders when the (manual feed) wood chipper is on the back - it makes getting the chipper to self feed a lot easier by adjusting the angle of the feed chute. Brian, at FitRite, did me a square deal.
-Jim
/ Hydrolic top link Pros? Cons? #7
Cons: cost, extra parts to fail (I still don't have great hose routing & have some related hose issues on mine)
Pros:
Best mod I've done on my tractor, I'd do it again in a heartbeat at twice the price.
Due to my TnT (Toplink & Tilt link) & Quick Hitch I can pick up any implement without getting off the tractor, no matter how crooked its sitting.
Makes running a box blade a dream. I can tilt forward to engage scarfires as needed from the seat. My L3200 has a notoriously jerky 3pt, but I can get excellent smooth driveways with the toplink. Tilt a hair forward to fill the box a bit faster, tilt back to smoothly make the box empty faster.
On my mowers I leave the toplink in float so that it follows contours nicely, but when I need to back over a ditch or swing the mower over something, I can lock it straight so it sweeps the ditch without falling in & twisting things up. I can lift the mower way up for clearance loading or maintenance (use a safety brace) at will to.
On my utility tractor which I use for all sorts of random stuff, my TnT has doubled the utility factor, its just so convenient. I'll never own another tractor without it.
/ Hydrolic top link Pros? Cons? #9
Same here... Haven't found a con yet. One of the bet improvements I've made to my tractor.
/ Hydrolic top link Pros? Cons? #10
Con, It ties up a remote. I use mine with a Harley rock Rake. It's great, but it's even greater using a quick attach set up. You extend the top hook which is rather deep, just grabbing the top pin a little ways, then pull the bottoms into place using the hyd top link, then lift. Puts a smile on my face, rather then fighting with the **** three point hitch!
/ Hydrolic top link Pros? Cons? #11
I agree with the others. There are really no cons. And for road maintenance or dirt work they are a marvel. Like TripleR said, no matter what you have on the 3ph the hydraulic top link will add to it's usefulness and convenience. Even a simple carry. You can make it dump or cradle a log.
I also got my TnT from Brian. His name says it all - Fit Right Hydraulics. He built my side cylinder so that I have more adjustment than any other one I could find.
gg
/ Hydrolic top link Pros? Cons? #12
There is a con!!! It makes you like the boy that calls his grandma, she is in one and phone in another and him in yet another room, and it makes you that way fast.
/ Hydrolic top link Pros? Cons? #13
If you have or get a 3 point pallet fork, a hydraulic top link is almost a necessity. :thumbsup:
/ Hydrolic top link Pros? Cons? #14
I have nothing "pro" to add that hasn't already been said. I can add that I went through Brian for my TnT, and he had never done one for my newer model tractor before. But the man knows his ... stuff, and after taking the requested measurements that he asked for, when it showed up there were no hiccups at all. It just installed and worked right out of the box. I can also add that the quality has to be seen and hefted to be believed. The walls are THICK and everything is welded. The finish is thick and tough as nails, not a bit o' paint shot on. That TnT will long outlast the zombie apocalypse. Absolute highest quality at a very fair price. I can think of no cons.
2012 FORD FOCUS SEL (A65054)
2012 FORD FOCUS...
2022 EZ-GO ELITE...
WOODS TS1680 - 14' ROTARY MOWER, 3PT (A64278)
WOODS TS1680 - 14'...
New/Unused Wolverine 44in Mini Grapple Bucket (A65583)
New/Unused...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
2021 BROWN & HUBERT 10' SPOOL TRAILER (A63276)
2021 BROWN &...
