Hydrolic fill Mitsubishi MT 372
/ Hydrolic fill Mitsubishi MT 372 #1
xmetzger
FRANCE
Mitsubishi MT 372
Hello everyone,
After an hydrolic liquid leak, i would like to refill the hydrolic fluid of my tractor. But i can't find the fill point! I've spent an hour searching, but impossible to find it! Even with the indications i've found on this forum.
A picture would be great if anyone has the time to take one.
Thank you very much in advance for you answers,
Xavier
/ Hydrolic fill Mitsubishi MT 372 #2
ITs right beside the transmission shifter. There should be a little black rubber plug. If you are sitting on the tractor it is just right to where 2nd gear is.
Pretty easy to find!
Thanks a lot for your answer!
Where can I check the level of the hydraulic fluid then?
/ Hydrolic fill Mitsubishi MT 372 #4
On the left side of the case (as you sit on the tractor) there is a little plug, (12 mm I think) Pull this plug, if gear lube comes out then the case is full. If not add it to the plug next to the shifter until it flows out of this hole.
I took a small 1/4 inch chunk of dowel and put it down the fill hole, you can then mark this dowel as full and use it as a dip stick.
Make sure you know what is in the case so you can add the same stuff
Ok, I will check this out tomorrow!
I found the plug and the fill point.
It seems to me that the hydrolic fluid is used both for the transmission and the hydrolics. Is that correct?
/ Hydrolic fill Mitsubishi MT 372 #7
Yep that is correct. I had 90w gear oil in mine at first but now have Universal tractor fluid which works much faster.
OK thanks!
/ Hydrolic fill Mitsubishi MT 372 #9
ok, gents. I just got one of these tractors, and I have a really stupid question: HOW DO I CHECK AND FILL THE ENGINE OIL?
Thanks in advance...
R
/ Hydrolic fill Mitsubishi MT 372 #10
The oil filler and dipstick should be on the right side of the engine. Fairly close to the the bell housing. Low on the motor. I have seen some with independent stick and fill port, and others (like mine) where the dipstick is attached to the fill port cap.
/ Hydrolic fill Mitsubishi MT 372 #11
Thanks. Found it. Now, how about the hydraulic fluid drain?? I found the fill hole, and I think I found the inspection hole (I think), but not sure how to drain the hyd fluid. And how much fluid is in there??
Thanks very much!!!
ron
/ Hydrolic fill Mitsubishi MT 372 #13
I am having an issue with my hydraulics. The 3pt hitch is locked in the raised position and it will not go down. I have tried everything that I can think of to include: Draining the fluid and checking the filter screen, (is there supposed to be a spring in or on the filter screen? the sticker on the fender mentioned a spring but I did not see one.) (even with no fluid and air in the lines it did not go down), refilling with fresh universal tractor hydraulic fluid, draining the air out of the system, adjusting the speed control on the area below the front of the seat, and checked the hydraulic pump by cracking each seal one at a time and bumping the key for each (NOTE: Do not squat down directly in front of the out side of the pump and have someone bump the key... You will be covered in fluid! Lesson Learned:)
On a separate note, where can I find solid rims for my front tires? The split rim 3 bolt pattern that I have are ridiculous!
Thank you so much for any assistance!
/ Hydrolic fill Mitsubishi MT 372 #14
Is this tractor new to you? Is it the first time you raised the 3pt? Is there an implement on it?.
When i brought mine home the previous owner had raised it and it stuck there. Likely it hadn't been raised in years and there was some corrosion at the top of the cylinder bore. The piston went up and stuck tight. I had to disassemble it and smack it down with a brass punch. Not too difficult.
/ Hydrolic fill Mitsubishi MT 372 #15
The tractor is not new to me... I have used it and maintained it for the past 2 years. I didn't use it much in the winter months but I did start it and operate all the functions at least once a month or so. It was covered with a tarp when not in use and a 2ltr bottle with the top cut off was placed over the exhaust even though it has a cap. I don't understand why it would stop working all of the sudden... Do you know if there is supposed to be a spring in or on the mesh filter on the right rear side of the tractor? The sticker on the fender mentions a spring but I haven't seen one and I can't recall if there was ever one on or in it. Thanks for any help!
/ Hydrolic fill Mitsubishi MT 372 #16
Hi I think I have a MY342D. I have a leak in a strange place it seems like it's just a cap.
John Deere Gator (A53317)
John Deere Gator...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
