hydro system filter
/ hydro system filter #1
passgas55
I have a 2210 and was unsure where the filter screen is on it. So I took a pic of where I think it is.
Am I right or going in the wrong direction?
/ hydro system filter #2
Right. Probably will need to pry it off once the bolts are out. Clean both surfaces, reassemble with #2 permatex. Drain transmission first or you will get soaked. Hopefully the picture you posted really needs to be rotated 90* clockwise.
I shot the pic by holding the cam sideways forgetting to rotate it afterwards. Either that or my tractor sleeps on its side:eek:
/ hydro system filter #4
Looks like the right spot to me. I just changed and cleaned my YM226, does seem to do better. It says in the manual to use the tractor and get the hyd oil hot and stop, then the sediment will be suspended (in filter). Before you open the drain plug ***open the dip stick and release pressure in it; if you don't you will get covered in hyd oil, like I did... It should be around 3 to 4 gallons of hyd oil.. When I removed my filter cover it did not have a gasket. I cleaned the surface and installed it back without anything on it. It is not leaking at all.... Have fun working on your TOY!!!
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
