Hydro-static Squealing
/ Hydro-static Squealing #1
AHARP
Rapid City, SD
LS XR4145
New to the club and bought my first LS. 2016 XR4145. Is it normal that when the forward pedal is pressed, when the engine is at an idol, for the hydro-static to squeal a bit? At half throttle or full throttle it is silent. Perhaps at low RPMs there is insufficient fluid circulating causing a noise? Thanks for any words of wisdom. I'm new to the Hydro-static transmission set up. Thanks.
/ Hydro-static Squealing #2
Consider yourself fortunate. My Kubota squeals at all speeds though it is more prone to squeal at low RPM in high range. It has lessened over time - or I'm more deaf.
/ Hydro-static Squealing #3
Yes, it's normal... with your throttle at idle the engine revs are under-powering the hydraulic pump.
Most HST tractors have a 'sweet spot', revolution-wise. My 4105's regular-use, non-PTO engaged, 'spot' is around 2100.
Oh, and g'day Mate and welcome to TBN from Downunder.
Enjoy the site.
/ Hydro-static Squealing #4
Yes. Like Wagtail says, increase your RPMs to increase your flow and it'll squeal less.
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2006 John Deere 6420 (A64126)
2006 John Deere...
Wheel Loader Forks (A64126)
Wheel Loader Forks...
Honda EM6500SX Generator (A62613)
Honda EM6500SX...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
