Hydro Saw
/ Hydro Saw #1
DAP
From Orange County NY to Lincoln County ME
JD LX288 and a B7800
We had a microburst blow through a few weeks ago. I'm minus about 6 large trees now. There was one large dead elm that took a lighting strike, broke into 2 and the top half landing on some utility poles.
The electric company sent out a huge cherry picker truck. In the lift bucket, there were some hydro remotes that the operator connected what appeared to be about a 10" chain saw on a 6 foot pole. This was the first time I saw a hydraulically operated saw.
If any of you have ever hand split elm before, you would really appreciate what this saw did to this tree. He went through what ended up being about 3/4 of a chord of dead elm, from his perch, like it was a Stihl saw through Ben & Jerry's Rocky Road.
Anyone else ever seen these saws? Better still, can they/are they being run from a CUT .... say a B series Kubota?
/ Hydro Saw #2
The only other place I have seen hydro type saws are in conjunction with cutting concrete and stuff like that. I have used a saw made by stanley check out stanleyworks.com they don't have much but a dealer list but they might be able to help.
/ Hydro Saw #3
It could have also been a pneaumatic saw. There are several brands of pneaumatic saws on the market also.
/ Hydro Saw #4
They are available in both Hydro and pneumatic. You could pretty much buy a loader for what the hydro ones cost, and the pneumatics ain't a whole lot cheaper.
The sad part is most of the cost is because of insulation and manufacturer's insurance, due to the use they'll be put to.
Every so often, a few turn up on Epay, used, or stolen.
/ Hydro Saw #5
Do a Google search on "hydraulic chain saws" - one of the listings is for:
ADI ACS - Hydraulic Chain Saw
OPTIONS:
16" chain saw bar.
Two hose 360° swivel.
Optional CE approval (European Standard)
High pressure oil filter - installed between quick coupler and hydraulic "IN" line.
Up to 88" in length
POWER REQUIREMENT
ADI Hydraulic Chain Saw
Oil flow - 12-20 Liter/Min.(3-5 G.P.M) -Max Flow
Max pressure 133 Bar (2000 P.S.I.).
Oil - Hydraulic oil 10-30 SAE.
Oil cleanliness - 10 Micron filtration.
Max oil temp. - 60°C (140°F)
Connecting threads 9/16 JIC 37°.
Open/Closed hydraulic system - on tool (Please see our Hydraulic Power Unit).
Sort of a Darth Vader/Light Saber approach to chain sawin'.
2017 BOBCAT MT55 STAND-ON SKID STEER (A64279)
2017 BOBCAT MT55...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2023 ASV RT-40 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-40...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
1993 WhiteGMC WG Tri-Axle Dump Truck (A61573)
1993 WhiteGMC WG...
