Hydro problem/KL401 loader . . .
/ Hydro problem/KL401 loader . . .
dfkrug said:
It seems to me, MARK, that for the regen function to work, the FEL
valve joystick has to be moved. Does the KL401 have a self-leveling bucket?
No self-leveling bucket on the KL401. :confused:
/ Hydro problem/KL401 loader . . . #12
The KL1231 loader on my 3054 does the same thing? I thought it might be air in the cylinders and was going to try bleeding them; now I don't have to, as it appears to be a common problem :eek:
My dealer is literally right up the street from my house so at lunch I am going to go talk to them and see what their thought is. I doesn't seem normal to me. Should be a warranty fix in my opinion.
Talk to two dealers and explained the issue and both said something sounds "off". I guess I'll take it to the dealer next week as much as HATE to do it. They end up keeping the tractor for like a week everytime I take it to them. Kind of hard to run a business without one of you main tools.:mad:
/ Hydro problem/KL401 loader . . . #15
Post their answer to the problem, if you would . Used my 3054 today and it is still doing "it", although not consistantly:confused: :confused: Hopefully, it's an easy fix, as mine is way out of warranty
/ Hydro problem/KL401 loader . . . #16
The system should be self bleeding, don't think you could end up with air in your cyls. or anywhere else for that matter.
someone please let me know if I am wrong.
Thanks,
Joel
/ Hydro problem/KL401 loader . . . #17
Not sure what you are experiencing. Can you shoot a video and possibly post on the web or, if coming to cookout, bring the video with you?
If you are dumping a load, the load can push the cyls down faster than the oil can recover, when this happens, there can be a pause for the oil to catch up. In other words, you dump a heavy load, then go to dump further, it takes a second for the bucket to react.
When you step into the bucket, do the pistons literally move in or out of the cyls?
Joel
/ Hydro problem/KL401 loader . . . #18
From what i know and my experience abot hydraulics, just by working the cylinder the air is automatically bled out. I still need to look closer on my CK30 to see where the slack is. I didnt pay any attention to see if its the pins and bushings or the cylinder. IF the problem is hydraulic in nature it is probably somewhere in the valve body. I would like to hear what a dealer/ mechanic has to say on the problem.
Ironically, I used it today to turn my manure pile and it didn't seem bad at all. When I was finished I parked the tractor back in the shed and had the bucket curled back with the cutting edge off the ground and the "heel" on the ground. I stood on the cutting edge and it would not budge. I jiggled the lever side to side to relive the pressure thinking that would "bring back the problem" but no dice. It only allowd the bucket to move just slight . . . what I would call within the tolerances of the normal play of the all the hinges/connection points/ brackets/etc. Go figure, I don't know what to think now.:confused:
/ Hydro problem/KL401 loader . . . #20
My thought is, for there to be a hydraulic problem bad enough that you could move by hand, you'd have not power to curl any kind of load.
I am thinking you are good.
Joel
Roto Grind 760 (A60462)
Roto Grind 760...
2014 HEIL CRUDE TRAILER (A60736)
2014 HEIL CRUDE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
CATERPILLAR 924F WHEEL LOADER (A59823)
CATERPILLAR 924F...
Hustler super Z zero turn (A56859)
Hustler super Z...
