Hydro problem/KL401 loader . . .
/ Hydro problem/KL401 loader . . .
dfkrug said:
It seems to me, MARK, that for the regen function to work, the FEL
valve joystick has to be moved. Does the KL401 have a self-leveling bucket?
No self-leveling bucket on the KL401. :confused:
/ Hydro problem/KL401 loader . . . #12
The KL1231 loader on my 3054 does the same thing? I thought it might be air in the cylinders and was going to try bleeding them; now I don't have to, as it appears to be a common problem :eek:
My dealer is literally right up the street from my house so at lunch I am going to go talk to them and see what their thought is. I doesn't seem normal to me. Should be a warranty fix in my opinion.
Talk to two dealers and explained the issue and both said something sounds "off". I guess I'll take it to the dealer next week as much as HATE to do it. They end up keeping the tractor for like a week everytime I take it to them. Kind of hard to run a business without one of you main tools.:mad:
/ Hydro problem/KL401 loader . . . #15
Post their answer to the problem, if you would . Used my 3054 today and it is still doing "it", although not consistantly:confused: :confused: Hopefully, it's an easy fix, as mine is way out of warranty
/ Hydro problem/KL401 loader . . . #16
The system should be self bleeding, don't think you could end up with air in your cyls. or anywhere else for that matter.
someone please let me know if I am wrong.
Thanks,
Joel
/ Hydro problem/KL401 loader . . . #17
Not sure what you are experiencing. Can you shoot a video and possibly post on the web or, if coming to cookout, bring the video with you?
If you are dumping a load, the load can push the cyls down faster than the oil can recover, when this happens, there can be a pause for the oil to catch up. In other words, you dump a heavy load, then go to dump further, it takes a second for the bucket to react.
When you step into the bucket, do the pistons literally move in or out of the cyls?
Joel
/ Hydro problem/KL401 loader . . . #18
From what i know and my experience abot hydraulics, just by working the cylinder the air is automatically bled out. I still need to look closer on my CK30 to see where the slack is. I didnt pay any attention to see if its the pins and bushings or the cylinder. IF the problem is hydraulic in nature it is probably somewhere in the valve body. I would like to hear what a dealer/ mechanic has to say on the problem.
Ironically, I used it today to turn my manure pile and it didn't seem bad at all. When I was finished I parked the tractor back in the shed and had the bucket curled back with the cutting edge off the ground and the "heel" on the ground. I stood on the cutting edge and it would not budge. I jiggled the lever side to side to relive the pressure thinking that would "bring back the problem" but no dice. It only allowd the bucket to move just slight . . . what I would call within the tolerances of the normal play of the all the hinges/connection points/ brackets/etc. Go figure, I don't know what to think now.:confused:
/ Hydro problem/KL401 loader . . . #20
My thought is, for there to be a hydraulic problem bad enough that you could move by hand, you'd have not power to curl any kind of load.
I am thinking you are good.
Joel
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
2019 Chevrolet AWD Equinox SUV (A59231)
2019 Chevrolet AWD...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2018 Ford Fusion Hybrid Sedan (A59231)
2018 Ford Fusion...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
