hydro pooring out
/ hydro pooring out #1
mccuen
I am trying to find out whats wrong with my farther-in-laws kubota b1550hds. He is elderly and can,t posably aford to take it to the dealer. the problem is when you fill it full of hydro fluid it gets in the engine which over fills the engine and over flows out a hose in valve cover (i assume this is and over flow for engine oil ) It only takes about 5 mins to completely out of hydro fluid. I called the dealer they said i had a filter stoped up somewhere . I changed one hydro filter but i have no idea where to find others.The manuals have been misplaced .Also i might add the filter i changed was completely caved in on the in side. changing this filter didn't fix it. "HOW CAN HYDRO FLUID GET IN THE ENGINE" THANKS..... /forums/images/graemlins/confused.gif
/ hydro pooring out #2
Welcome to TBN. /forums/images/graemlins/smile.gif
The Hydraulic pump is mounted on the engine.
Pump may have a bad seal that is pumping oil into engine.
/ hydro pooring out #4
Like was said, the hydraulic pump is bolted to the front of the engine. There is a seal that is on the shaft in the pump. That seal can go out and cause that problem. It is an easy job to take the pump off and replace the seal. I think that if you can do a oil change, you could change the seal.
/ hydro pooring out
thanks, that was the problem.
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
CHEVY DUALLY TRUCK BED (A65643)
CHEVY DUALLY TRUCK...
John Deere 1770NT Planter Drive (A65640)
John Deere 1770NT...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
