Hydro oil change interval
/ Hydro oil change interval #1
tiogajoe
Little Marsh, Pa
Kioti CK2610hst
I'll be coming up on just about two years since I changed both filters and hydro oil to mobil 424. I maybe have 130 hours since. My manual seems a bit vague. I take it trans oil and filters every 200 hours? Just wondering what you guys do? BTW fluid is super clear.
/ Hydro oil change interval #2
Yep, my CK30HST has a 200 hr interval recommendation but after breakin and full drain I installed Amsoil Tractor/Hydraulic oil and new filters. At 400 hrs I had the oil analyzed and it came back good for continued service. I changed the filters, topped up the oil and will sample in 200 hrs…But you’re good for a bit yet. However, why not get a UOA kit and sample your HST fluid at 200 hours or so. You might be able to extend your interval too. The report would have good info on the condition of both fluid and equipment.
/ Hydro oil change interval #3
Who did you get the UOA kit from? I've been thinking of doing this on my cars too since each is unigue; a 15 yr old straight 4L 6 cyl, small hi reving 1.8L 4 cyl and turbo flat 2.5L 4.
/ Hydro oil change interval #4
Black stone labs is pretty popular and most heavy equipment dealers will also have kits available. However, I use Oil Analyzers through the Amsoil website as it’s their oil that I’m using. The reports are quite detailed.
/ Hydro oil change interval #5
My Kubota manual says 400 hours. I watch it - If it is not crystal clear (hard to see) then I would change it. Otherwise, 400 hours. If it is clean and clear, 200 seems really soon. But then, Kubota udt2 cost $110 a pail and takes 3 pails. So cost a lot with filter to make the change. Especially if it is not necessary. What does the Koiti manual say?
/ Hydro oil change interval #6
My OP Manual say change hydraulic fluid every 600 hours. That's exactly what I did. I also changed the hydraulic fluid filters @ 600 hours.
/ Hydro oil change interval #8
In post 2 I advise that my Kioti interval is 200 hours, which I think does comes quite quickly, for me anyways. I agree that if it looks good it’s “probably” still good?! But UOA will verify what direction to take. I don’t hook up anything else to the remotes since I’ve sold the wood splitter.
/ Hydro oil change interval #9
New Holland Workmaster 50 change filter at first 50 hours and then filter and hydraulic fluid every 600 hours.
/ Hydro oil change interval #10
I have given my opinion so often I sometimes feel like a broken record. (I suppose I would still be dating myself were I to say "endless loop".)
Around $30 for an analysis from a reputable lab is much cheaper than an hydraulic oil change and is pretty cheap peace of mind that you are not harming the system.
/ Hydro oil change interval #11
Under warranty it would be best to go by manufacture establish requirements.
/ Hydro oil change interval #12
I go by the manual but the old fluid looks just like the new. I am going to run a fluid ck every 200 hours after I get past the warranty period.
/ Hydro oil change interval #13
Well I just did a full fluid & filter changer at 40hr on my CK2610. Engine oil was black and hyd oil was dark amber. 400hrs seems like a long time, but I don't have much experience with diesel equipment. Oil analysis seems like a good idea.
/ Hydro oil change interval #14
From the manual it says to change HST and Transmission filter only at 200hr oil and filters at every 400hr after the initial period
/ Hydro oil change interval #15
From the manual it says to change HST and Transmission filter only at 200hr oil and filters at every 400hr after the initial period. So are you saying no oil change ever, just the filters? Yah, okay…
I will probably get an oil analysis done.
/ Hydro oil change interval #19
You’re right. I missed the punctuations….😬
And punctuation is important!
Let's eat grandma! is not the same as Let's eat, GrandMa!.
There is book called Eats, Shoots and Leaves on that very subject. The author was a frequent speaker on a talk show. Funny woman.
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2022 EZ-GO ELITE...
2019 P.J. Trailer Trailer, VIN # 4P5F82029K1307542 (A65563)
2019 P.J. Trailer...
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
John Deere 6125R (A60462)
John Deere 6125R...
