Hydro help
/ Hydro help
Bone dry and nothing while running
/ Hydro help #42
No fluid Dirty filter or sheared keyway on the pump shaft Hoye # HWK 522 Shaft key. Very rare for a pump to go bad. That's what I would look for next is the Shaft Key. Keyway/Shaft keys good Then I bet the pump went out.
/ Hydro help #43
This thread has progressed rapidly today. Not for sure what I am looking at in your earlier pictures but want to think those quick connects are coming off a diverter block on your three point. If so I suspect you have deadheaded your pump. Was everything working before taking those quick connects apart?
/ Hydro help
Yes everything was working. I didn't even start the tractor. I got the whole plow system off. I had to jack the front of the tractor up to pull out everything. I started it up and it didn't work.
/ Hydro help
I sure hope it's a keyway that price looks way better than the price for the pump.
/ Hydro help #46
If you find a sheared key or worse and repair it then don't crank again until you complete the circuit at the diverter block or it will happen again.
/ Hydro help
I don't understand complete the circuit? I really don't want it to happen again.
/ Hydro help
And diverter block is that where the two valves are under the seat? Sorry my first tractor and hydros
/ Hydro help #49
The diverter block is what you pictured in post #9. The lines with the quick disconnects are coming out of it.
Before disconnecting the quick disconnects to your snowblower the fluid traveled out of the diverter block and through the snowblower system and back into the 3 point at the diverter block. That is the circuit. When you unplugged the quick connects the pump or fluid was dead headed. One solution is to fab up a loop hose with a quick disconnect on each end to match the ones on the diverter block . Plug the hose on and the fluid can complete the circuit.
I apologize for my lack of word usage. Not good at explaining things.
You should have a control valve of some sort on your snowblower. Any chance of a picture of it?
I don't want to be held accountable for any bad advice I am giving here. I certainly don't have enough info on your system to do much recommending. Just based on what I am seeing I think it is dangerously plumbed. :confused3:
/ Hydro help #50
Here's my (previous) YM186D with a return hose connecting Out to In on its diverter block. The hose replaces a loader or something that is no longer on the tractor. You can't pump fluid against a closed quick-connect, it has to go somewhere and this return hose is the best solution.
231625d1317339837-loader-plumbing-p1650636rym186d-dividerblock-jpg
/ Hydro help
Oh ok. I did not know you had to have something hooked up to those disconnects for it to work. I thought the 3. Would just work. Could it start working now if I just got that hose in?
/ Hydro help
I will post a picture of he plow piece in the morning. Again thanks everyone for the help!
/ Hydro help #53
If correct about what we are seeing it will not start working again with a loop hose until pump key, coupling, or pump is repaired:cryingeyesout:.
/ Hydro help #55
Have you used it with the plow off before or is this the first time?
/ Hydro help #59
Are these custom made? Or can I just buy one ?
Yes. :D
Get the numbers off of the connectors to be sure to get the correct type.
For a quick fix, remove the shortest hose from the plow, take the connector of the other hose and make your loop.
Do not use Teflon tape on the threads, get some paste thread sealant.
2004 Mack CH613 Concrete/ Water Mixer Truck (A64194)
2004 Mack CH613...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
24" Mini Excavator Bucket (A66285)
24" Mini Excavator...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
LAYMOR SWEEPMASTER 400 (A65643)
LAYMOR SWEEPMASTER...
