Hydro Gear Transaxles
/ Hydro Gear Transaxles #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
I replaced the oil in a axle that I have which is weak when hot. I used 2050 Mobil synthetic in it. The old oil was definitely heavier and dirty black. Has anyone ever rebuilt one of these units. Mine is a 318-0319 model number /314-0510 series. I found a good used one cheap but the model number is 166786 and the same series number 314-0510. The linkage setup is different on the 166786 but and might be interchangeable by switching out the linkages. I could also try putting in 50 weight racing oil as I do not use this mower in cold weather.
/ Hydro Gear Transaxles #2
I am a Hydro-gear dealer so I do an occasional rebuild if it is cost feasible. Sounds like you have scored the internal pump/center section/motor parts and in the process of complete failure. Hydro-gear dealer site doesn't have a way to compare trannies so I can't tell you the differences between the units.
Thanks for the info. I'll call Hydro gear to see is they can help me out. I also have a 3000 series transaxle that is from a real garden tractor that I could install in my Cub if it is doable.
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
Frontier BB5048L (A64126)
Frontier BB5048L...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A59914)
2015 FREIGHTLINER...
