hydro fluid leaking out the breather
   / hydro fluid leaking out the breather #1
stripercity
This is my third post recently, you guys are a big help. The steering is fixed, the clutch is getting better it seems, but when i was running the PTO Oil came out of the breather under my seat. The tractor is a beaver 2 wheel drive. Is the most likely cause a clogged filter? Is there anything else that might cause this? The pump seems to work fine, plenty of power. It lifts the 4' finish mower off the ground relatively easily. Thanks again guys
   / hydro fluid leaking out the breather #2
It may be too full or have some detergent oil in it.
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2017 Ford Expedition 4x4 SUV (A50324)
2017 Ford...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2012 Ford Escape Limited SUV (A50324)
2012 Ford Escape...
Bush Hog 10' Pull Rotary Mower (A50774)
Bush Hog 10' Pull...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
