Hydro control peddle...
/ Hydro control peddle... #1
gravelman
Platinum Member
NH
Kubota 2650
Hi folks...gravelman here..i have a 2015 Kubota 2650 the hydro peddle is not returning to neutral without bringing it there with the foot... i do not believe it is a lubrication problem as most of the linkage is free etc. I guess there are springs in there ?? before i go to dealer etc...any suggestions on what i might expect It also sticks in either forward or reverse which obviously is dangerous on close up work. Thanks for any advice...
/ Hydro control peddle... #2
Take a close look at the roller and the cam it rides in...the cam becomes wallowed out, and doesn't center anymore. On my L2800 (which should be close), I experienced the same thing. Cheap enough fix. Two bolts on the cam, snap ring holding the roller.
/ Hydro control peddle... #3
As mobilus wrote also check for debris.
Ok im not much of a mechanic but i will take a looksee...THANKS VERY MUCH
/ Hydro control peddle... #5
Not a Kubota guy, but on my machine the springs are exposed and just under to floorboard. Hope it’s an easy reattachment if a spring or something similar.
/ Hydro control peddle... #6
On my JD 4010, one of the hydro pedals lost a pin that kept it from returning.
Ralph
Ok guys...thanks much..i will look at it closely tomorrow...and report back...THANKS ALOT...
2015 Isuzu NPR-HD Box Truck, VIN # 54DC4W1B3FS807576 (A65563)
2015 Isuzu NPR-HD...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
1996 Ford F-350 Pickup Truck (A64194)
1996 Ford F-350...
2015 International ProStar T/A Day Cab Truck Tractor (A64556)
2015 International...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
John Deere 2 Row Corn Planter (A65579)
John Deere 2 Row...
