Hydro control peddle...
/ Hydro control peddle... #1
gravelman
Platinum Member
NH
Kubota 2650
Hi folks...gravelman here..i have a 2015 Kubota 2650 the hydro peddle is not returning to neutral without bringing it there with the foot... i do not believe it is a lubrication problem as most of the linkage is free etc. I guess there are springs in there ?? before i go to dealer etc...any suggestions on what i might expect It also sticks in either forward or reverse which obviously is dangerous on close up work. Thanks for any advice...
/ Hydro control peddle... #2
Take a close look at the roller and the cam it rides in...the cam becomes wallowed out, and doesn't center anymore. On my L2800 (which should be close), I experienced the same thing. Cheap enough fix. Two bolts on the cam, snap ring holding the roller.
/ Hydro control peddle... #3
As mobilus wrote also check for debris.
Ok im not much of a mechanic but i will take a looksee...THANKS VERY MUCH
/ Hydro control peddle... #5
Not a Kubota guy, but on my machine the springs are exposed and just under to floorboard. Hope it’s an easy reattachment if a spring or something similar.
/ Hydro control peddle... #6
On my JD 4010, one of the hydro pedals lost a pin that kept it from returning.
Ralph
Ok guys...thanks much..i will look at it closely tomorrow...and report back...THANKS ALOT...
2009 TROXELL KILL TRAILER (A63569)
2009 TROXELL KILL...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
FEED TANK (A63290)
FEED TANK (A63290)
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2018 John Deere 8345R MFWD Tractor (A63109)
2018 John Deere...
