hydraulics
/ hydraulics #1
dogshow
2022 lovol tb504
hi, bought a 2022 lovol tb504 tractor, and got a quick mount blade for front loader, i am not getting to angle it each way, tractor as a 3rd function joystick, got no hyd. oil coming to cylinder ,tried bleeding, no work,tractor is new with 22 hours. i don't know if it is got to do with hydraulics or electrial,or the joystick itself.got any idea's.thanks.
/ hydraulics #2
Tractor hydraulics are self-bleeding. Try connecting to a different implement or cylinder. If it still doesn't work either, the problem is in your accessory control on the tractor. Often that control is a push button that works an electric solenoid that opens a valve to allow hydraulic fluid to flow. First thin to check is that voltage is getting to the solenoid.
/ hydraulics
thanks for your reply.i will check it out.
/ hydraulics #4
Wow, that's a nice tractor I hadn't heard of before. Must be for the Euro-Asian markets only. The no-DEF 50hp engine gave it away. And a remarkable 10-year, 3500-hour warranty is off the charts. Wish we had those here. I wonder if there's a rebadged equivalent in the US.
2016 CHEVROLET CAPRICE CAR (A66091)
2016 CHEVROLET...
2019 Nissan Kicks Hatchback (A66738)
2019 Nissan Kicks...
2018 PETERBILT 579 (A67714)
2018 PETERBILT 579...
2003 Johnson 50hp 4-Stroke Outboard Boat Motor. (A66738)
2003 Johnson 50hp...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
