hydraulics
/ hydraulics #1
Modemman
St. Clair, MO
mahindra 6500
What is the easiest and cheapist way to add an extra set of couplers on a Duetz Allis tractor?
/ hydraulics #2
Tell us what you have for hydraulics.
/ hydraulics
it has one pair of couplers already, but to run a round baler, i need two pair.
i have another tractor to bale with, but wanted to have both in case something happen to the other, i could bale with the other.
I have seen valves to put into the existing one, and uses electric switch to use two at a time, but it is kinda expensive to me. Any help would be appreciated, JJ. Thanks
/ hydraulics #4
If your valve is a mono block valve you will have to add another valve in series.
If it is a stacked valve, you can add to the stack.
A selector/diverter valve will take one input and provide two outputs. Use a switch to switch between which cyl or motor.
/ hydraulics #5
Did it come new with the one you have now or was it added later? Might be able to just get a 2 or 3 spool valve and replace the old one.
2014 FEATHERLITE GOOSENECK LIVESTOCK TRAILER (A63291)
2014 FEATHERLITE...
UNUSED WOLVERINE QUICK COUPLER 4 (A64281)
UNUSED WOLVERINE...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
Challenger 236/246/248 Skid Loader Parts and Service Manuals (A63117)
Challenger...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2016 Autocar Xpeditor T/A Side Loader Garbage Truck (A61573)
2016 Autocar...
