Hydraulics
   / Hydraulics #1
Dirtfarmer456
Charleston,WV
Ford601
I have a Ford 601 hydraulics just stopped working. What is most common cause? Is there an easy way to check and see if pump is pumping?
   / Hydraulics #2
Older tractor did you check the fluid?
   / Hydraulics
Yes DABSGT checked fluid dipstick shows a little over full.Is there an easy way to see if pump is pumping ?
   / Hydraulics #4
On my NAA (and I think your 601 is the same) there is a little plate on top of the hdyraulic under the right front corner of the seat that is where you mount the valve for remote hydraulics. If you removed that plate and cranked it over I would think you should make a big oily mess if the pump is working. The plate is about 3 or 4 inches across and has a hump in the middle. I hope this helps.
   / Hydraulics #5
I was just out and looked at our NAA. On it the hyd pump drives off the flywheel. On it you could disconnect the pressure line (small line) and see if it pumps out fluid.
   / Hydraulics
Thanks for the info Oldtractorfixer Iwill check that plate under seat. The lines are all internal. Thanks again forthe info.
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A53843)
HYDRAULIC TILTING...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A53421)
2025 ZWB 59in...
2012 Jeep Liberty SUV (A53424)
2012 Jeep Liberty...
