hydraulics
/ hydraulics #1
chevyman003
how do i get faster control of my loader going up and down and the bucket as well ? something to do with the orfices ? dont know ?
/ hydraulics #2
What kind of tractor. I you fill out your profile it will help when you ask questions.
Bill
/ hydraulics #3
Orifices, hose size, cylinder size, pump flow, valve. Many things have a bearing on how fast a cylinder moves. Without knowing the tractor or the your setup, it's hard to make a suggestion.
/ hydraulics #5
Faster is more volume. Bigger pump and or higher rpms. It could also be the pump in leaking internally, the cylinders are leaking internally or the control valve is leaking internally.
/ hydraulics
its a L225DT 24hp 4x4 tractor,the pump works fine but is very slow.
/ hydraulics #7
You have a plugged filter, waterlogged fluid, poor valve, poor cylinders, poor pump, piece of *** across the pump inlet, etc. Given your other post about broken castings, it sounds like this tractor need a thorough going-over. Had it long?
2018 Freightliner M2 106 Single Axle Dump Truck, VIN # 1FVACXFC4JHJM9637 (A61165)
2018 Freightliner...
2012 Chevy Impala Sedan (A61569)
2012 Chevy Impala...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
UNUSED ATS 4'X300' GRASS PROOF CLOTH (A62131)
UNUSED ATS 4'X300'...
2009 Down to Earth Trailers DTE7610G29 10ft. S/A Utility Trailer (A61569)
2009 Down to Earth...
2014 Jeep Grand Cherokee SUV (A61569)
2014 Jeep Grand...
