Hydraulics weak?
/ Hydraulics weak? #1
Fishingfoolemjak
Sylva, NC
Ford 1320
Hello everyone. I haven稚 been on in a while, but I finally got around to doing some maintenance on my new to me (inherited) ford 1320... yesterday I changed the oil which was blacker than the ace of spades. And I changed the fuel filter (also black, and deteriorating) after which I learned all about how to bleed air from fuel lines!
Pic of fuel filters:
Anyways. My neighbor has a little kubota and he can put his bucket on the ground and lift the front end of his tractor up off the ground. I tried to do this with my bucket, and it won稚 lift my tractor. I知 wondering if my hydraulics are weak or if this is normal?
I haven稚 addressed the hydraulics yet. I知 not sure what to do other than change the filter and maybe add some fluid. I plan on doing it this week or next weekend. Any info or help would greatly appreciated! Thanks in advance.
Here she is running after I learned to bleed air from the fuel lines... probably simple to y誕ll, but I was pretty proud of myself for figuring it out!
/ Hydraulics weak? #2
Can you lift the front end up if you tilt the bucket down? Might need more space for the cylinders to move.
Aaron Z
/ Hydraulics weak?
I’ve tried just pushing with the arms, and I’ve tried laying the bucket on the ground and then rolling it down... neither works.
/ Hydraulics weak? #4
/ Hydraulics weak? #5
If the fuel filter looks like that I would change the hyd oil also with the filter. Looks like nobody serviced the tractor for a long time:)
/ Hydraulics weak? #6
Good point, it is possible that your hydraulic filter and/or strainer is plugged and is causing hydraulic system issues.
Aaron Z
/ Hydraulics weak?
Ok, I値l get a new filter and oil this week. Can anyone tell me how to check the hydraulic oil level? I see where the drain is, I see where to fill it up (above the pto?), I see where the filter is, but don稚 know where a dipstick is....
/ Hydraulics weak?
/ Hydraulics weak? #9
The bucket cylinders typically have regen (search for it here on TBN for more info), which makes them rather weak (but faster) when dumping. Try dumping the bucket so it's vertical before trying to lift the front end with the boom cylinders.
But as others have said, check the relief valve pressures for a definitive answer. Clean fluid on an unknown maintenance history is always a good idea too.
/ Hydraulics weak? #10
I have tried it revved up..... where do I get this gauge? Tractor supply?
Any local hydraulic place can supply you with gauge and fittings. Around $30.
You can even get them to put a short length of hose between the gauge and quick coupling so you can see it while doing the test.
Disconnect any quick coupling and plug in the gauge.
Run tractor at full rpm and then use control lever to direct hydraulic flow to port where gauge is.
Read immediately and release control lever. It just takes a second or two to get the reading.
Dave M7040
/ Hydraulics weak? #11
/ Hydraulics weak?
I know where the screw in filter is, under the right rear fender, are there any other filters or screens I should be looking for?
This week I’ll pick up the fluid and the filter.. next weekend it’s gonna get changed!!
/ Hydraulics weak? #14
Look on Messicks.com, they should have a parts breakdown that will show if there are any other filters (usually, there is a strainer on the suction (intake) side of the pump and a screw on filter on the return line from the hydraulics (power steering, loader, 3 point, etc as equipped).
Aaron Z
/ Hydraulics weak? #15
If you are getting your fluid/filter from a Ford/New Holland dealer they will be able to tell you where the fill is and how to check for full.
/ Hydraulics weak?
Thanks guys! I’m getting my fluids and filter from a local NAPA store. But I may try to find a dealer, usually there’s nothing for about 50 miles as far as dealers go...
/ Hydraulics weak? #17
Maybe do a Google search? Pretty amazing what can be found if you can figure out how to word the question properly. :)
/ Hydraulics weak? #19
You get it fixed yet?
/ Hydraulics weak? #20
on my 1620 fluid dipstick is on the floor right below the seat...
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
3146 (A63117)
3146 (A63117)
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
PORTA POTTY (A67714)
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
