HYDRAULICS vs DIRT
/ HYDRAULICS vs DIRT #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I'm sure debris can cause havoc with hydraulics. When I disconnect my grapple, how should I protect the hoses and QD's from dirt??
/ HYDRAULICS vs DIRT #2
You can buy dust caps for the QD's from alot of places.
/ HYDRAULICS vs DIRT #3
I use a double baggie with duct tape over the ends of mine. I can't seem to keep those dust caps on
You cover both male and female components of the QD ??
/ HYDRAULICS vs DIRT #5
TSC sells male and female caps.
I use the caps PLUS.. I leave a can of wd-40 ont he tractor at all times.. befroe any QD gets plugged in, I hold the flip down cap open and hose out the femal side, and then i hose off the male end.. and usually wape on a clean cloth,if available. The wd won't hurt the orings. and may even help them glide in without scuffing or wearing as much. I use the little straw so i get a good stream / presure. Since a wd-40 can is so cheap.. i make sure the qd's are real clean... don't want no dirt inmy hyd system if i can help it.
Soundguy
/ HYDRAULICS vs DIRT #7
I don't know how you're set up, but if you can get your QD's so that one is male and one is female, then you just hook the QD's into each other. This also helps with hooking things up. You won't get things hooked up backwards if one is male and one is female.
This works for the hoses. As for the remotes on the tractor, I guess you're back to dust caps. The other option would be to get a short piece of hose with a male QD end and a female end and then use that short piece of hose connected between the out and in of the QD's on your tractor. Make sure the hose is long enough that the two ends of it can be hooked together to keep them clean too.
The chunk of hose with ends on it won't be cheap, but it will be cheaper than damage due to dirty hydraulics.
/ HYDRAULICS vs DIRT #8
Yes.. the male side caps will have the cap on a teather with a retainer ring. slip the ring over the male end, then pull out and cap when not in use. The female side will have a plug.. though some femal QD also have a flip down cap. I know the CNH deluxe hyd qd's do. When the male end is installed inthe QD.. snap the male/femal caps together to keep -them- clean.
they come in about as may colors as tractros do. i was able to get a green set to go on my jd 1517 mower..
Soundguy
MISC PALLET OF TRUCK PARTS (A65643)
MISC PALLET OF...
NEW Wolverine 78" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 78"...
Kinze KM3000 Monitor (A65640)
Kinze KM3000...
Bulk Bin (A66408)
Bulk Bin (A66408)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2022 EZ-GO ELITE...
