Hydraulics system over heat light appears on my john dear 6330 tractor
   / Hydraulics system over heat light appears on my john dear 6330 tractor #1
Vince7
Mildura Vic
John deer 6330
Hi all,
I am having problems with my John dear 6330 tractor. The hydraulic system overheat light has come on and I have replaced all hydraulic filters, transmission filters and am now thinking it could be a faultily sensor. Has this happened to anyone else or any other suggestions for what else could be wrong.
Thanks heaps
   / Hydraulics system over heat light appears on my john dear 6330 tractor #2
You might check all relief valve, and the hyd radiator if you have one.
Next time the light comes on, stick one of those long stem cooking thermometers in the hyd tank and check the temp.
Look in your manual for the temp that causes the light to activate.
   / Hydraulics system over heat light appears on my john dear 6330 tractor #3
Welcome to TBN. :welcome:
Could be a bad sensor, but you are just guessing. Sensors can be very expensive, and that might not fix it.
Have you checked with the service manager at your local dealer? He might know of similar problems on other tractors.
I suggest that you post your question in the John Deere section of the forum. There will be more JD owners reading there than in hydraulics.
   / Hydraulics system over heat light appears on my john dear 6330 tractor #4
A hand held temp gun with a laser pointer might give you an idea of the temps you have. You could check external lines, filter housings, oil cooler etc.
   / Hydraulics system over heat light appears on my john dear 6330 tractor #5
One note on the IR temp gun - Do not take readings from chromed or plated parts, they will give you a bad reading. Anything made of rubber, plastic or painted with non-metalic paint is good. Also be aware that the farther away from the target they larger the area you are measuring.
ISZ
   / Hydraulics system over heat light appears on my john dear 6330 tractor #6
If that model has a sump screen and you haven't checked it, it could be the problem.
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2239 (A51244)
2239 (A51244)
2016 CATERPILLAR 313FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
RoGator RG1100C (A55302)
RoGator RG1100C...
