Hydraulics qustion
   / Hydraulics qustion #1
CK732
Massy
How easy or hard is it to install 2 more hyd ports?.
   / Hydraulics qustion #3
Assuming you're wanting to add them to your tractor, you need to look at your hydraulic valve assembly to see if you have a "power beyond" port, as well as a output and backflow port for the additional lines. If not, you'll need to replace (or possibly add) another valve body in order to operate add't'l ports effectively.
You can't just go and add a "T" to an existing line like you can for adding a water line to your house.
Yeah it's on my tractor so I'll look and see if I have room on the body.
   / Hydraulics qustion #5
Summit hydraulics has good info on this. I've had good experience with both their products and presales support.
   / Hydraulics qustion #6
Not hard if you know what you are doing and have the ports on the tractor. One of mine needed a power beyond spool and the other was a CaseIH kit that just bolted on. One was cheap and the other about $650. Guess which one.
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
8 Ton Combo Pintle Hitch (A48081)
8 Ton Combo Pintle...
2013 Ford Expedition SUV (A49461)
2013 Ford...
2014 Jeep Grand Cherokee Laredo SUV (A48082)
2014 Jeep Grand...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
