Hydraulics on JD 5105
   / Hydraulics on JD 5105 #1
jbwrangler
Bronze Member
New to the forum.
I have a JD5105 (2000 model) that had 2 rear SCV's controlled by two levers beside the seat. The tractor has a 553 loader that is plumbed into the rear remotes.
Is there a way to convert this to a joystick and or mid-hydraulic set up? Can I keep the rear outlets?
Not sure what my options are for adding hydraulics on this tractor.
Thanks in advance.
   / Hydraulics on JD 5105 #2
You can add a mid scv as shown. It does not interfere with your rear hydraulics.
Thanks. Exactly what i was looking for. Any idea what something like that would cost?
   / Hydraulics on JD 5105 #4
Would this configuration be an option for a 4520 for a grapple or other FEL mounted hydraulics? Learning about SVC's and options.
   / Hydraulics on JD 5105 #5
4520 comes standard with the mid scv ( two of them) operated by the joystick. For a grapple you can install a diverter on your existing to switch one function back and forth or install a separate 3 rd rear and the fel third hard line kit and run it to the front. If your 4520 is 2011 or newer the 3 rd is electro hydraulic and is controlled by a thumb switch on the joystick. If older it is a lever that fits in the slot next to the 3 pt lever.
   / Hydraulics on JD 5105 #6
Okay, that makes sense now. My 4520 is a 2008 and has the joy stick for the FEL. I am learning about hydraulics and how best to expand its use. Thanks for the feedback.
   / Hydraulics on JD 5105 #7
Thinking about this further, what are the options for a 3rd function to the FEL for this optional use? Are there just the two options that you mention, a diverter on the mid SCV or a 3rd function on the rear running up to the front?
CATERPILLAR 325FL EXCAVATOR (A51242)
CATERPILLAR 325FL...
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
