hydraulics issue
/ hydraulics issue #1
busaman
johnstown, pa
new holland tc40d
I have a TC40D with hydrostatic transmission and a front end loader. I purchased it used with very few hours. It was making a low squealing noise when I got it and the bucket did not go up smooth all the time. I have since taken the bucket off to use my brush hog. Hog and 3 point hitch was working fine. But, the drive started making a loud squeal and pedals became soft and it would not move forward or back. I let it cool and it started to work again. Took it up to garage and took hog off and put bucket on. Problem has gotten worse. I put a new New Holland hydraulic pump on and checked all my lines. All are clear. (That I can see)
Tractor bucket barely goes up and tilts up and down very jumpy and slow. Now tractor will not move at all. (forward or back) Any ideas?
/ hydraulics issue #2
Fluid level okay? Clean? Have you changed it or the filter(s)?
I would have tried a little more diagnosing before dropping $$$ on a pump that may not have been needed.
/ hydraulics issue
oil level is a little bit high. But, it is clean and freshly changed. It is something that effects the bucket and the transmission.. They both work, but just barely.
/ hydraulics issue #4
Check all quick disconnects to make sure they are plugged in.
3pt Vicon Fertilizer Spreader (A64912)
3pt Vicon...
(2) Goodyear 16.9-24 Tires (A64911)
(2) Goodyear...
Baby Goat Decorative Statue (A66738)
Baby Goat...
2010 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2010 ALLMAND...
2019 CHEVROLET TAHOE (A66091)
2019 CHEVROLET...
Swict QA 78" Bucket (A64912)
Swict QA 78"...
