Hydraulics are weak.
/ Hydraulics are weak.
Just doesn't seem to have the digging power it had when new.
/ Hydraulics are weak. #23
Do the hyd. on the FEL and the backhoe both seem weak. I was wondering if you might have a seal in a cyl. leaking by. This would not effect the whole tractor.
/ Hydraulics are weak. #24
/ Hydraulics are weak. #25
Put a gauge on the valve body, "seem to have" is hard to quantify.
Gauges are cheap. If there are pressure concerns, by all means mount one and check your readings.
/ Hydraulics are weak. #26
I'm heading out to the local TSC store this week. Will get a gage to put on then. Does seem like the best place to start! So far the main issue seems to be with the backhoe. Not so much with the FEL. Left it loaded yesterday. Only dropped about two inches overnight with a load of stone in it.
/ Hydraulics are weak. #29
Daveman, an easy way to check a hydraulic pump is to dead end (dead heading) a hydraulic circuit and listen for the pressure relief to unload (buzzing sound). A weak pump does not have the gpm capacity to blow the relief off. Of course, a non-visual internal leak between the pumps pressure side and sump side will also prevent pressure from rising to relief valve settings. Generally, not absolute, any pump that can blow off it's relief valve is probably ok on a gpm check.
On your loader, roll the bucket all the way back and listen for the relief valve buzz. Also, if you know where the valve is (external only) put your hand on it to feel the vibration.
For an on the fly test, when going down a mild grade rolling the bucket all the way back, on some tractors, will cause a slight tractor hold back as the hyd pump is forced to pump against the relief valve setting. This hold back can be easily felt on must small tractors.
When buying a pressure gauge, get a male coupling to match up with bucket roll back female coupling and test here. Most tractor hyd pop off pressures are between 2,000 and 2,500 psi.
Dave, after reading your second post I note the problem seems to be more with the backhoe. Don't forget, that the hoe has a pressure relief valve of it's own. If this setting is higher then the tractor setting then the tractors valve will go off before the hoe's. In fact, the back-hoe's relief valve will probably never go off. This is not a good thing with relief valves since they may stick shut if never used at all.
If pressure test at loader fails, disconnect hoe lines and retry.
If pressure good on re-try then problem could be an internal leak from pressure to sump in hoe's valve body.
By the way, backhoe digging specs are based on hoe's factory relief valve setting. If tractor setting is below hoe setting then the hoe may not be the hoe the factory specs say it is.
good luck,
/ Hydraulics are weak. #30
good luck,
Tried your idea on the relief valves. Both the FEL and the Hoe will hiss if you try to send them past there stop points. So I'm guessing the pressure is OK! On a pressure gage I had about 2,100 to 2,500 psi. (Fluctuated if you touched anything.) Seems everything on this tractor is Hyd. Turns out there is two pumps on it. One for the steering and clutch. The other for the Hoe and FEL. Did find out if I disengage the flow to the Hoe. (No I didn't mean that to rhyme!) The hoe doesn't settle hardly at all. Even the FEL with some large rocks on it will stay up for the day. Dealer did come to the house and check it after I put the gauge on it. Said everything was in spec. So maybe I'm just getting to used to what it can do. So I'm expecting more. Told the Wife it may be time for a bigger tractor. She just smiled and said "NO!" /forums/images/graemlins/frown.gif. Thanks everyone for the ideas. I never really knew anything about hydraulics so this has been a definite learning experience! /forums/images/graemlins/smile.gif
2022 EZ-GO ELITE...
2013 International WorkStar 7400 Crane Truck, VIN # 1HTWGAAR0DJ296617 (A65563)
2013 International...
2012 Deere 120D (A64126)
2012 Deere 120D...
2016 FORD E450 SHUTTLE BUS (A59914)
2016 FORD E450...
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNGK26K97G305720 (A65563)
2007 Chevrolet...
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
