hydraulic ?
/ hydraulic ? #1
perthbrad
perth western australia
shibaura d235f
hi all , was pushing some leaves with my bucket , hit a rock wick stopped the tractor in its tracks , enough force to dent the bucket , the hydraulics started to strain , slow etc and could hear the straining , got a bit worse where it was stalling the tractor , i just parked it up , what do you think I've done , who do i get to fix it , thanks brad
/ hydraulic ? #2
Did you lose any fluid?
Is it a hyd transmission?
Is the problem with the drive train or the FEL?
/ hydraulic ?
no fluid lose , boom was fine ,strained on bucket and 4in1 , engine started stalling with the strain
/ hydraulic ? #5
With FEL valve in neutral, does the engine still strain and do you hear the relief valve squealing?
Does the bucket and lift work normal?
Does the engine still stall?
/ hydraulic ?
valve was squealing when running , once it stalled want start now , turns over , , was driving fine after it happened , just can't start it now
/ hydraulic ? #7
You might try removing the hyd pump and try starting.
Does the engine even try and turn over, or does it seem locked up?
/ hydraulic ? #8
valve was squealing when running...
Your accident may have strained the IN or PB hoses to/from the loader valve, and if it has
QDs on it, caused one to close, stopping the implement pump flow.
/ hydraulic ? #9
Yes. This fits. A hose could have closed up internally. It would have to be the hose supplying the FEL valve or else the return hose. Hoses from work ports would have no effect while the FEL valve is centered.
larry
/ hydraulic ?
tractor turns over fine , was running fine , just strained more and more , once it started stalling ,i just parked it , i have no mechanical knowledge at all , someone else said some sort of safety ore shutoff in the hydraulics probably kicked in , thanks guys ,you have put me at ease a bit , was thinking the worse , got an older guy whos been around tractors for along time coming out ,
/ hydraulic ? #11
FEL valve work port OR return hose problems will not cause his symptoms. But, the Power Beyond hose from the
FEL being interrupted would, as would the IN hose.
On my old Kubota L2550, it was often happening that my 3-pt lift cylinder control lever would get knocked
up into the top of its travel, causing the implement pump to go into relief. It did not have a functioning
limiter. The symptoms would also be the like the OP's above.
/ hydraulic ?
most of the strain would happen at first from the 2 ,4in1 controls ,not so much the boom , the strain became worse ,then the tractor stalled , now turns over but don't start , its like the strain built up to the point the engine stalled , for me i do feel more at ease ,not having any knowledge ,that it seems hydraulics , hopefully when i get someone out ,its simple , fingers crossed , thanks guys
2002 Sterling M8500 Acterra Landscape Dump Truck (A66736)
2002 Sterling...
2005 little wonder high output blower (A64557)
2005 little wonder...
2013 John Deere 544K Articulated Wheel Loader (A66734)
2013 John Deere...
2019 INTERNATIONAL DURASTAR 4300 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
2006 Stephens Aluminum 407 T/A Chemical Tanker Trailer (A68183)
2006 Stephens...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
