hydraulic ?
/ hydraulic ? #11
It would have to be the hose supplying the FEL valve or else the return hose. Hoses
from work ports would have no effect while the FEL valve is centered.
FEL valve work port OR return hose problems will not cause his symptoms. But, the Power Beyond hose from the
FEL being interrupted would, as would the IN hose.
On my old Kubota L2550, it was often happening that my 3-pt lift cylinder control lever would get knocked
up into the top of its travel, causing the implement pump to go into relief. It did not have a functioning
limiter. The symptoms would also be the like the OP's above.
/ hydraulic ?
most of the strain would happen at first from the 2 ,4in1 controls ,not so much the boom , the strain became worse ,then the tractor stalled , now turns over but don't start , its like the strain built up to the point the engine stalled , for me i do feel more at ease ,not having any knowledge ,that it seems hydraulics , hopefully when i get someone out ,its simple , fingers crossed , thanks guys
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
S/A Yard Dog Truck Tractor (A59230)
S/A Yard Dog Truck...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2014 VOLVO VNL (A60736)
2014 VOLVO VNL...
WATER TRAILER (A58214)
