HYDRAULIC WHEN USING 3 POINT ON L35
/ HYDRAULIC WHEN USING 3 POINT ON L35 #1
BOTAL35
MONTGOMERY , AL
95 KUBOTA L35
HELLO, IAM BRAND NEW TO SITE. MY THREE POINT ON MY L35 PULSES UP AND DOWN WHEN I HAVE BUSH HOG ECT ATTACHED. THIS ONLY HAPPENS WHEN POSITION CONTROL LEVER IS BETWEEN FULLY RAISED OR FULLY DOWN.
TRACTOR HAS 1125APROX HOURS. IS THIS NORMAL.
ALSO IT WILL NOT HOLD RAISED WHEN TRACTOR IS TURNED OFF. /forums/images/graemlins/confused.gif
/ HYDRAULIC WHEN USING 3 POINT ON L35 #2
Most times when this problem occurs I have found unless you find something obviuos stuck in the valve which is located under the top cover/hyd cylinder/rockshaft, replace the valve itself and that will take care of the problem. I have in the past disassembled everything only to find nothing wrong and as a last ditch effort replaced the valve with good results. As a side note, make sure that the pto/backhoe diverter valve is fully engaged and the loader diverter (remove the cover with four bolts and the 3 ph drop speed knob just below the seat and make sure the small slotted screw in the line under the panel is turned fully clockwise [I think] or counter clockwise ) if the loader stops working you went the wrong way..................... could also be leaky cylinder seal but "usually" does'nt pulse, just drops when fully raised after feed back link shuts of 3ph hyd's.
THANKS I WILL CHECK IT OUT THIS WEEK END.
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
John Deere 5055E (A64126)
John Deere 5055E...
iDrive TDS-2010H...
2021 New Holland 1428 Rake (A63688)
2021 New Holland...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
