Hydraulic valve
/ Hydraulic valve #1
Ivan49
Lake City Mi
Kubota L 3301
I have a 3 spool Hyd Valve and it has 3/4 inch threads on the inlet side and on the outlet side there is an Aluminum fitting that is tapped in the middle for a 3/4 inch return line. There is a plug on the top of the valve for another return line. This is a Gressan valve and has F 20 stamped next to the outlet. The aluminum plug seats tight against the outlet from the spool on the inside of the valve body. Can the 2nd line on the outlet be plugged so that I can use this as a normal valve. Thanks Ivan
/ Hydraulic valve #2
How about a picture of the valve?
The other ports could be a second return port or a PB port or an unloader port.
Does it look anything like this?
Trailmobile Van Trailer (A63689)
Trailmobile Van...
2461 (A58376)
2461 (A58376)
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2022 John Deere 612R Sprayer (A63111)
2022 John Deere...
2009 International 4300 Bucket Truck 55' (A62613)
2009 International...
