Hydraulic toplink for JD 5520
   / Hydraulic toplink for JD 5520 #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a JD 5520 and want to get a hydraulic toplink (top-n-tilt) for it. The question is, do I get one with a check-valve built in or does the tractor itself have a "check valve" built into it?
I would think the cylinder would drift down on it's own but am not sure.
Anyone have any experience with this general type of JD and a hydraulic top link?
   / Hydraulic toplink for JD 5520 #2
Buy one with a double acting check valve. I would suggest the same for the tilt cylinder as well. I ran for years without having check valve cylinders and it seemed that the tilt cylinder would bleed off much faster than the top cylinder would. Still, it's much nicer to not have to worry about constantly re-adjusting the cylinders. If you are doing grading work with the tractor, there are plenty of other things to pay attention to rather than worrying about whether your cylinders have moved without your permission. ;)
   / Hydraulic toplink for JD 5520 #3
Get the one with the POCV (Pilot Operated Check Valve) from CCM and you will have no regrets. Your tractors (I saw your other post also) do not have check valve "built in"
   / Hydraulic toplink for JD 5520 #4
kennyd -
Perhaps you could enlighten us dummies? I'm a bit new to this tractor thing. I did a search on google for "CCM" but did not get anything useful. :eek:
Thanks!
-- Dave
   / Hydraulic toplink for JD 5520 #5
CCM is Carter & Carter Machinery:
Carter and Carter Machinery, Hay Equipment Headquarters
The cylinders can be seen HERE.
The "box" attached to the cylinder is the POCV, it basically keeps the cylinder from drifting-even if a hose blows! This has been discussed here for years. Regular cylinders can drift due to poor seals in the cylinder itself, or from leakage in the remote that they are hooked to.
   / Hydraulic toplink for JD 5520 #6
I understand. Thanks for the quick reply.
Thank you all for the great advice---
I put a post into "Build it yourself" regarding the possibility of making check valves with quick attaches and just snapping into each line rather than buying cylinders with check valves built in. That way I could have one set of those and mulitple cylinders --cat one and two--for different tractors.
thanks
2022 John Deere 4066M Heavy Duty MFWD Tractor (A53342)
2022 John Deere...
2003 SUZUKI VINSON 500 ATV QUAD RUNNER (A51247)
2003 SUZUKI VINSON...
2000 HONDA FOURTRAX 300 ATV (A51247)
2000 HONDA...
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
