Hydraulic Top Link
/ Hydraulic Top Link #1
Compact1
Southwest Michigan
2006 New Holland TC33DA with SS, R4 loaded tires, 2 rear remotes, arms rests, & rear light
I just ordered a hydraulic top link and hose kit from Carter and Carter Machinery, Inc. in Tennessee. Mark was very helpful and I'm looking forward to receiving his product. Check out their site at http://www.ccmachinery.com/TNT.htm
Has anyone else ordered a top link for a New Holland TC33DA? If so, I was wondering which cylinder you chose. I ordered the 18" to 26.5" with check valve.
/ Hydraulic Top Link #2
Got mine (18-26.5) a couple of weeks ago. (Farmtrac 300DTC)
How could I live without it!!!!!!!
/ Hydraulic Top Link #3
No, but I am definitely jealous! :D That's been on my want list for a very long time... but there are still too many other *mandatory* things in the way that must be bought first. :rolleyes:
Dougster
/ Hydraulic Top Link #4
Dougster
Hi Doug,
Just wanted to say this one might be one of those "mandatory" ones though. It is so handy you will kick yourself for not getting it sooner!:D
/ Hydraulic Top Link #5
3RRL said:
Hi Doug, Just wanted to say this one might be one of those "mandatory" ones though. It is so handy you will kick yourself for not getting it sooner!:D
Oh, I hear you loud and clear Rob. :) And less expensive things do sometimes move to the front of the line! :D But four things still sit there on the list ahead of any and all discretionary items... and, sadly, this is still a discretionary item! :eek:
Dougster
/ Hydraulic Top Link #6
I have been looking to get a hydraulic top link for a while now. My tractor has the hydraulic connector on the back. Can't I just buy a cylinder and hook it into the connector?
/ Hydraulic Top Link #7
Is the rear port connected to a valve control of some sort or is it a Power Beyond? If it's the former, yes. You'll just need to add the hoses and quick connects (or have the guy you get the toplink from install them). If it's a Power Beyond port you'll need a valve of some sort, like I did here.
/ Hydraulic Top Link #8
I have two controls inside the cab that go to the ports. I think the previous owner had a hydraulic top link and a hydraulic "vertical arm" (I don't know the correct name for this part).
Anyway, can't I just order a 1" cylinder from xyz store and install it? I know I will have to make sure the length is right. Or is there something that I am missing?
/ Hydraulic Top Link #9
I've had one from CCM for about six months now and it is very handy. While it makes hooking up very easy (no more threads!) it also makes UNhooking challenging. I just spent ten minutes today unhooking my box scraper because I couldn't find the 'null spot' where there was no tension on the top-link so I could unhook it. Any tips here?
-Brian
/ Hydraulic Top Link #10
That will work, but you'll probably want to cannibalize an existing toplink to weld the ends on. I ended up with a CCM toplink because I haven't gotten a welder yet.
As for finding the sweet spot where you can unhitch the implement I haven't run into the issue yet (but I don't swap implements that often). I do generally use a mallet or hammer to get pins out, if you get close enough to level that may work. I also made the lever for the toplink face backwards so I should be able to tap the pin with the hammer as I move the toplink back and forth until the pin gives easily (stay clear of the implement, of course!). Finally, I also am using undersized hoses (1/4" instead of 3/8") so the toplink may move slower than it would with the appropriate hoses, idling down should slow it down even more and make fine adjustments possible.
/ Hydraulic Top Link #11
Sounds like you have the remotes to run hydraulic cylinders for the 3 pt hitch which are often call a top n tilt or a t and t system. And yes you could run any cylinder if you can find the right size. Where you will have a problem is finding the proper size with the proper travel and also you will have to have the proper ends welded to it after cutting the existing ends off. If you have those skills it can be done, several here on the forum have done it.
If you are going to have to take them to a machine shop for modification you may be better off cost wise just buying the ones from the dealer listed above. Another advantage to the ones Mark at CC Machinery imports is they have a built in check valve. This keeps the cylinder from leaking down while in use so you do not have to readjust them once set. The check valve system seems to be hard to find at the xyz store.
MarkV
/ Hydraulic Top Link #12
-Brian
Somewhere there was a thread that suggested/recommended a free link in the top link. I don't remember why, or what problem it was trying to solve, but it was basically a couple of links of big fat chain added to the top link to give some slack there. It might have been to reduce some sort of kicking up and bending of the top link, I don't remember.
Chain links that are big and fat enough to take a 7/8 pin through.
Anyhow, something like that might work to help find the slack spot.
/ Hydraulic Top Link #13
MarkV
What should I be looking for in size and travel? The northern tool catalog has several different sizes.
/ Hydraulic Top Link #14
First thing - a 1" cylinder is not big enough - the ram will be too small to take the load. When I built mine I used a 2 1/2" cylinder with a 1 1/8" rod with a stroke of 8", cost me $59 from Surplus Center. Had to cut the ends off, bought weld-on swivel eyes from TSC and at this time I fine-tuned the retracted length of the rig by cutting "X" amount off the rod before welding the end on. Every tractor's 3ph is a little different, you need to take an accurate measurement of retracted length for your hitch & implements. On my tractor, 16" retracted from center to center of the swivel eyes worked perfectly. You will find with most implements that the retracted length is the most important, with an 8" stroke I have never had to extend it that far out to use it, it's all in shortening the toplink to get good angles for the boxblade and getting the tail of my bushog up high enough to get it on my trailer etc. I also installed a Prince double-pilotted check valve - there are different opinions on needing one, my toplink definitely stays put with the valve whether the tractor is running or not, can't say without it, never tried. If your hydraulic controls are all tight as a drum, you probably don't need one but as parts wear, you might experience some leak-down.
As far as you guys that are having trouble getting the toplink pin out of your implement, I've never had that problem. My retracted length is shorter than any I could find ready-made at the time, that's the main reason why I built my own. My whole rig with hoses was only slightly cheaper than buying from CCM, but their retracted length was too long to get much use out of my 3ph. On my boxblade I use a short piece of treated 2x4 on each front side of the box as they are worn-down on an angle and the box wants to roll forward when released from the hitch. With the 2x4's in place I can jog my toplink to center the pin just fine and it slips right out. Don't have a bit of problem with my rotary or PHD.
/ Hydraulic Top Link #15
Interesting - I'll do a search. That might not help me in this case because the box scraper needs a rigid top-link. For the bushhog it is great because there's no problem since it wants some slack anyway.
-Brian
/ Hydraulic Top Link #16
-Brian
I move the remote slowly until I see the pin rock ever so slightly on the implement end. The pin then comes out fine.
Surplus Center now has cylinders with the swivel balls on several different lengths and diameters of cylinders. The ball is kind of close to the stationary end on the cylinder. I have to put the cylinder in the top draft hole to keep the cylinder from hitting the third arm mount.
/ Hydraulic Top Link #17
I like those prices at Surplus Center! :) I could almost do that today! :D
So do I really need the check valves or not??? :confused:
Dougster
/ Hydraulic Top Link #18
Dougster
I would say no. I do not have them on mine and have not needed them. I may be wrong, but I do not think that any that you buy from Kubota or John Deere or implement manufactures have the check valves. None of the commercial tractors that I have seen have them. But then again most of the tractor world could be wrong.:rolleyes:
If you get one, get a 3" cylinder and be done with it.
Remember that if you buy it, that was your food money for the rest of the year.:D :eek:
/ Hydraulic Top Link #19
MtnViewRanch said:
I would say no. I do not have them on mine and have not needed them. I may be wrong, but I do not think that any that you buy from Kubota or John Deere or implement manufactures have the check valves. None of the commercial tractors that I have seen have them. But then again most of the tractor world could be wrong.:rolleyes: If you get one, get a 3" cylinder and be done with it. Remember that if you buy it, that was your food money for the rest of the year.:D :eek:
You rich left coast folks really like to rub it in... don't ya??? :p
Brian, I think I am limited to a 1-1/2" bore for a Cat I 3-point... otherwise the pins won't match the pin holes:
http://www.surpluscenter.com/pages/035.pdf
Dougster
/ Hydraulic Top Link #20
Dougster
Bushings man, bushings.
Doug, make one yourself, it's the only way to get it right. Buy the 3" cylinder, buy an aftermarket top link, a little cutting and welding and you have a hydraulic top link that is the right size for your tractor.:)
And it only costs you 6 months worth of meals, didn't you say that you needed to go on a diet? Although the only diet that I can think that you might need to go on would be a real food diet and get off that peanut butter & bread diet, that gets old quick.
Oh well, more food for thought.;)
CASE IH 290 AFS MAGNUM TRACTOR (A64280)
CASE IH 290 AFS...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
Caterpillar 980G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 980G...
(1) 24X9.50-12 TIRE W/ 5 LUG RIM (A64280)
(1) 24X9.50-12...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
